RPM fluctuates on higher load
Old Jan 15, 2020 | 06:49 AM
AJTracey's Avatar
Default RPM fluctuates on higher load
Hello,
My JAG (XF 2.7D), when on higher gears (4th sometimes 5/6 usually) and accelerating lightly, has RPM fluctuations.
It gets down slightly then gets back to the previous position. It happens until I shift the gear to the lower one, or accelerate harder. It seems like the engine is suffocating a little bit at that moment. There is also a sound (seems to come from underneath) for that moment when the RPM is at a drop point.
I have changed MAF (there are 2), the computer diagnostic readings are alright for the airflow.
Sorry if I have missed the same topic somewhere in the forum, but I was unable to find one so I created a new thread.
Old Jan 16, 2020 | 08:18 AM
AJTracey's Avatar
Unhappy Additional info
At the drop moment, the sound from underneath seems like a vibration. All the fluctuation seems to be periodic.
Old Jan 20, 2020 | 01:33 PM
Mike1234's Avatar
Question XF 2.7D RPM Fluctuations
Originally Posted by AJTracey
Hello,
I also have a 2008 XF 2.7D with the same characteristics, although mainly in 5th gear. RPM fluctuations and strange sound exactly as you describe.
My XF has over 190,000 miles on the clock and I have had if for 18 months. I was a bit concerned when I first noticed, but it hasn't caused any problems or got any worse. I recently drove from the UK to Croatia for a holiday, a round trip of 3,000 miles without incident. I'd like to know what is happening, just for peace of mind, so please add an update if you find anything.
Old Jan 21, 2020 | 04:57 AM
AJTracey's Avatar
It hasn't caused any problems for me either. However, I thought it might in the future. I hope it is nothing serious, but still want to find the cause of it. Will let you know if something comes up.
I still hope someone from this forum will explain more about this issue.
Old Feb 14, 2020 | 07:53 AM
AJTracey's Avatar
Does anyone else experience this? Any advice?
Old Feb 14, 2020 | 08:35 AM
Jssaab's Avatar
I had a similar thing ( and a few others) with a petrol version after a tune. slight surge when at constant speed when more torque was requested (incline in the road, bridge etc) . Lie 100 rpm. Very annoying. especially with cruise control set. Was not so pronuonced at very high speeds (over 75 MPH It was fixed with a new tune.
Have there been any software updates for the 2.7D perhaps?
Old Feb 17, 2020 | 01:48 AM
AJTracey's Avatar
Could you please elaborate on "tune". is it the ECU tuning known as "chipping"?
How can I check if there are any software updates for 2.7D? We do not have JAG official dealer in my country.
Old Feb 17, 2020 | 06:18 PM
Jssaab's Avatar
Sorry yes, ECU tune.
If you are stock you should see if the current software version is updated
Old Feb 18, 2020 | 02:49 AM
AJTracey's Avatar
Where can I see if it is updated?
Old Feb 19, 2020 | 06:14 PM
Jssaab's Avatar
Since you don' thavce a dealer nearby you shoudl think about getting a SSD device to repair your car
Old Nov 14, 2024 | 05:32 AM
flagstone's Avatar
Old Thread, I know, but have any of you ever figured out what the issue was / got it fixed?
I have the exact same issue on mine (XJ 2.7D). The noise when the RPMs drop sounds like turbo compressor surge.
Stav
Dec 22, 2016 04:44 PM
beckman007
Jan 25, 2013 09:26 PM
Alphaman2402
Nov 4, 2008 08:39 PM
kcamacho11
Jun 27, 2008 08:52 PM
