Service interval confusion...
Old Oct 18, 2016 | 05:28 PM
stmcknig's Avatar
Default Service interval confusion...
2010 XFR was serviced at 45000 about a year ago.
Service needed light comes on today at 49900.
I thought the next interval was 65000.
Is it just an oil/filter change because of the one year anniversary ?
Old Oct 18, 2016 | 05:38 PM
10 XF Premium's Avatar
I bet the servicing shop did not reset the reminder indicator.
Simple, just google it and there are several vids on how to reset it by yourself.
Old Oct 18, 2016 | 05:41 PM
Mikey's Avatar
Most likely. Jag wants the oil change annually unless the mileage limit is reached first. I don't think any Jag has a 20,000 mile oil change interval.
Old Oct 18, 2016 | 05:42 PM
OzXFR's Avatar
Yep, service is due at 16k miles or 12 months, whichever comes first, and the "service due" light monitors both distance and time, as well as driving style.
The services alternate "A" and "B", where the A service is a simple engine oil and filter change and the B service is the same as the A service with the addition of some other filter replacements, sometimes just the cabin/pollen filter, and a bit more thorough inspection/test of various parts and systems. If your warranty has expired then I recommend doing the service yourself, it's quite simple and costs a fraction of what a dealer will charge.
Old Oct 18, 2016 | 05:49 PM
stmcknig's Avatar
Thanks all - I've had the brakes/disks/fluid changed out and the air and cabin filters done when I got the car in January. I'd have assumed that if they didn't reset it properly at 45K (they were an indie Jag shop) it would have been hassling me before now.
So the consensus seems to be dump the oil and filter after a year and only 5K miles...?
And yes I can do it myself, I just have to go down the rabbit hole searching for the "best" oil as I think the kosher Castrol stuff is only available in big drums at the dealership.
Old Oct 18, 2016 | 05:55 PM
I read your post too fast, I missed the one year bit. L just looked at your miles.
I change mine every April, always seems to have about 10,000 to 12,000 miles on it.
If it has been a year, I would have the oil and filter change.
Old Oct 18, 2016 | 06:03 PM
OzXFR's Avatar
The "best" and "correct" oil for the XFR has been debated to death on here.
You simply need a full synthetic 5W-20 oil that meets or exceeds Ford WSS M2C925-B or 945-B, it doesn't have to be the factory "recommended" Castrol brew. Plenty out there which meet this spec, including Mobil 1, Motul and Millers.
Old Apr 29, 2017 | 05:52 AM
Moe Farrag's Avatar
personally i change the oil every 7-8k miles on my xf. my engine fried due to oil within a year of having the car due to oil. luckily i was under warranty so my dealer was able to help and have warranty replace the engine. Oil isnt designed to last 12k+ miles. in the catalogue it states to change the oil every 10k miles or less IF DAILY DRIVEN. but i have a 2012 im not sure about the 2010. Id rather be safe than sorry 100 dollar oil change is a lot easier to handle than a 40 grand engine personally.
