slight vibration steering wheel
Old Jul 4, 2016 | 02:02 AM
jaguarxfv8's Avatar
Default slight vibration steering wheel
Since a couple of months I've noticed a slight vibration in the steering Wheel. (the vibration increase when I go faster) -__-
I've took the car back to get the Wheels balanced, no change
I've told my tires dealer to check the rims for a bent or anything, but nothing
I even changed tires but no change, still feel that anoying vibration.
I'm starting to think it's because I changed the front upper control arm on only the right side, although I checked the left one and it was fine. now I'm like I will have to lift up the car again and check everythings out, like is it the lower control arm, the tie rod etc ??
Did anyone of you already experienced this kind of steering vibration ?
Old Jul 4, 2016 | 03:42 PM
10 XF Premium's Avatar
Brake rotors can cause that as well. If you buy new ones, make sure they are balanced. They balance them by grinding small amounts of metal off the edges.
Quaility rotors are balanced from the factory, but cheap discs are not.
Old Jul 4, 2016 | 03:48 PM
jaguarxfv8's Avatar
Thanks but it's not my brake pad or rotors I changed them 6 mounth ago and cope them from the jag dealer ! I found my problem is a wheel bearing
Old Jul 5, 2016 | 10:55 AM
DPK's Avatar
DPK
What year is your car?
Old Jul 6, 2016 | 11:04 AM
jaguarxfv8's Avatar
jaguar xf v8 supercharged 2009
Old Jul 6, 2016 | 11:22 AM
DPK's Avatar
DPK
Thanks..Not being nosey, just looking at trends of problems with age..
Old Sep 13, 2016 | 12:20 PM
09XFwhippin's Avatar
How can I tell if my bearings are bad?
Old Sep 13, 2016 | 12:59 PM
Bigg Will's Avatar
Good Find! Thanks for the update on your fix.
Old Sep 13, 2016 | 05:31 PM
Alejandro Flores's Avatar
I had a similar problem but 3 of my tires and wheels were bad. Got all 3 replaced. Vibration never occurred again.
Old Sep 14, 2016 | 09:10 AM
Blackcoog's Avatar
I'd say the vast majority of Jag owners would have it based on wheel/tire issues since our wheels are so soft.
f_in_seattle
Sep 20, 2017 11:18 AM
tr8bofin
May 1, 2016 07:30 PM
orangeblossom
Apr 15, 2016 01:05 PM
Zenman63
38
Dec 31, 2010 02:50 PM
