Sportbrake antenna removal
Old Mar 31, 2021 | 04:14 AM
dougndins's Avatar
Question Sportbrake antenna removal
Hi
I need some help.
The GPS signal is lost and I have a replacement antenna to fit BUT I can't seem to drop the head liner without damaging it.
I have removed the two visible torx screws holding the rear post plastic trim on but can't seem to free the lower ends. Any ideas what to remove next? I don't want to brute force it.
Has any body got the workshop manual for a 2013 Sportbrake? The saloon version doesn't cover this.
Chris
Old Mar 31, 2021 | 03:12 PM
JBzXJ40's Avatar
Yep sure do - have a look below
PUBLISHED: 11-MAY-2011
2013.0 XF (X250), 419-07
NAVIGATION SYSTEM
NAVIGATION SYSTEM ANTENNA (G1057932)
REMOVAL AND INSTALLATION
  • 86.62.06
  • GLOBAL POSITIONING SENSOR ANTENNA - RENEW
  • ALL DERIVATIVES
  • 0.20
  • USED WITHINS
REMOVAL
  1. Remove the interior lamp lens.
  2. Release the interior lamp.
  3. CAUTION:Make sure that the latch is pressed before disconnecting the electrical connector.
    Release and disconnect the 2 electrical connectors.
    1.
      • Remove the 2 nuts.
      • Remove the reinforcement plate.
  4. Remove the global positioning sensor (GPS) antenna.
INSTALLATION
  1. To install, reverse the removal procedure.
    1.
      • Tighten to 6 Nm.
Old Mar 31, 2021 | 03:43 PM
Brake buster's Avatar
sadly , thats for the saloon , the sportbrake rear passenger light is no where near the antenna connector
you need to remove all the plastic trims and roof handles to drop the headlining , it is a right pain to be honest
BB
Old Mar 31, 2021 | 10:19 PM
JBzXJ40's Avatar
Yep you're right - my apologies, got side tracked
You can get to it without dropping the entire headliner, but yes you will need to at least drop the rear seat grab handles, and the D-Pillar trims
If I remember, there is a big yellow clip that holds up the rear section of the headliner - I call it the Big Bird clip - it will most likely break, practically unpreventable. The part number I have is JRC2D22430, it may have been superseded by now
PUBLISHED: 01-OCT-2012
2013.0 XF (X250), 501-05
INTERIOR TRIM AND ORNAMENTATION
D-PILLAR TRIM PANEL (G1567815)
REMOVAL
NOTES:
  • Removal steps in this procedure may contain installation details.
  • Some variation in the illustrations may occur, but the essential information is always correct.
  1. CAUTION:Apply heatshrink or protective tape to the end of a suitable tool to protect the interior components.
  2. Refer to:Left Loadspace Trim Panel - Sportbrake (501-05 Interior Trim and Ornamentation, Removal and Installation).
    PUBLISHED: 30-DEC-2012
    LEFT LOADSPACE TRIM PANEL - SPORTBRAKE (G1567821)
    • 76.19.22
    • LUGGAGE COMPARTMENT SIDE LINER - LEFT HAND - RENEW
    • ALL DERIVATIVES
    • 0.50
    • USED WITHINS
    REMOVAL
    NOTES:
    1. Retract and remove the parcel shelf.
    2. Lower the rear seat backrest.
    INSTALLATION
    Refer to:Right Loadspace Trim Panel - Sportbrake (501-05 Interior Trim and Ornamentation, Removal and Installation).
    RIGHT LOADSPACE TRIM PANEL - SPORTBRAKE (G1567822)
    • 76.19.23
    • LUGGAGE COMPARTMENT SIDE LINER - RIGHT HAND - RENEW
    • ALL DERIVATIVES
    • 0.40
    • USED WITHINS
    REMOVAL
    NOTES:
    2. NOTE:Left hand shown, right hand similar.
    3. Lower the rear seat backrest.
    4. NOTE:Left hand shown, right hand similar.
    5. NOTE:Left hand shown, right hand similar.
    INSTALLATION
INSTALLATION
Old Apr 1, 2021 | 02:30 AM
dougndins's Avatar
Many thanks Brake Buster and JBzXJ40.
That was the answer I was afraid of.
Would love to meet the designer of that option.
That's my Easter weekend sorted.
Much appreciate the help.
Chris
Old Jun 20, 2021 | 11:14 AM
Andymanzan's Avatar
Default Looking for help
Originally Posted by dougndins
Hi
I need some help.
Chris
Hi Chris, I have a 2014 sportbrake and I have to remove the shark fin aswell as my gps doesn't work, it's possible to give me any information about how did you do it if I need to buy the yellow clip etc, any information will be appreciated as your post is the only one I have found about jaguar estate. Thank you in advance
Old Jun 22, 2021 | 05:33 AM
dougndins's Avatar
I followed the instructions posted above. All is good and as described but it is a real pain.
I re-used the yellow clip - use a trim removal tool. But to tidy up the rear edges of the liner I resorted to some double sided tape as the door trim stops just short.
Be sure to have the correct antenna unit before you start. I didn't which was frustrating..
Good luck - you'll need it.
Chris
Old Jun 22, 2021 | 07:47 AM
Andymanzan's Avatar
Hi Chris Thanks for your reply, where did you buy the antenna from and how i can get the correct one without removing it? Just model and registration number should be enough? Thanks
Old Jun 22, 2021 | 08:35 AM
dougndins's Avatar
I had taken it out. I would hope the dealer could tell you. It's model is very dependent on sales location and entertainment options.
They do appear on popular auction sites as the cars are written of!
Chris
Stuart xk
Oct 2, 2021 10:43 AM
danke
Dec 4, 2020 09:17 AM
retsel
XE ( X760 )
Sep 14, 2020 03:44 PM
JayW
May 29, 2020 07:59 AM
jahlack
XJ40 ( XJ81 )
Aug 8, 2016 11:31 PM
