stainless brake lines on xfr
Old Jun 13, 2022 | 10:09 PM
wimmer's Avatar
Default stainless brake lines on xfr
want to get some stainless brake lines for my 2010 xfr. Anyone in the states do this upgrade if so where did you get your lines?
Thank you
Old Jun 13, 2022 | 10:22 PM
OzXFR's Avatar
Thank you
All XF brake lines are braided stainless steel from the factory it's just that you can't see this coz they have a rubber outer cover.
Old Jun 14, 2022 | 06:56 AM
wimmer's Avatar
oz as always thanks for the insight. my mechanic is saying that he thinks they are collapsing inside thus the calipers are slow to release?
Old Jun 14, 2022 | 06:57 AM
wimmer's Avatar
xf/ xfr same lines?
Old Jun 14, 2022 | 08:10 AM
OzXFR's Avatar
xf/ xfr same lines?
Fairly sure they are the same, I had an XFS and an XFR and worked on the brakes on both and couldn't see any differences in the brake lines and I have never read or heard of any differences. Of course the brakes themselves differ across the various XF models, with different size rotors calipers and pads, and some owners have upgraded the cooking model brakes to XFR spec brakes with no need to change the brake lines.
Old Jun 14, 2022 | 02:20 PM
wimmer's Avatar
based on your experience do the lines go bad? I have a 80k mile xfr reasonable driving and the tech that works on it said he thinks the inside of the lines are collapsing slowing the return of the calipers, if they are stainless doesn't that seem far fetched?
Old Jun 14, 2022 | 07:09 PM
BritCars's Avatar
Mine is a 2010 XF SC and I've not experienced any issues with the brake lines. And I don't recall any posts here related to brake line issues in the many years I've been here
If there really is an issue then you could just replace with the Jag OEM lines. But it's not clear to me why he thinks there is an issue?
Old Jun 14, 2022 | 07:47 PM
wimmer's Avatar
Brit the story is I had the front brakes done rotors and pads, within a few thousand miles the rotors warped pretty bad. the issue is I'm in wisconsin so a few thousand miles equals over two years, thus no warranty. So I got some brembo rotors and he said he thought the old ones warped because when I let off the brakes the inner lining of the line is colapsing slowing the return to a place where thae pads arent generating heat on the rotor. I don't know much about this stuff so I thoiught I would see what others that do know these cars think. I wondered if it was just an excuse for poor rotors the first time. Did he really put oem stuff on like he said?
Thank you all for the help
Old Jun 15, 2022 | 01:01 PM
clubairth1's Avatar
Community Influencer
If the calipers are dragging and not releasing that is your answer. Your mechanic is just reaching and does not understand Jaguar's as OzXFR posted they already come with SS lines and we don't have any reports of them collapsing like the old rubber ones do.
May need to replace the calipers if the pistons are dragging?
Make sure the caliper pins are free and lubricated as in salt county this is a very common problem.
Old Jun 15, 2022 | 02:30 PM
kansanbrit's Avatar
How much were they warped ?
Old Jun 15, 2022 | 04:02 PM
wimmer's Avatar
enough that they pulsated pretty bad, I found it wierd that it was both of them
really think that it was shitty rotors that weren't oem but its hard to throw accusations without proof and they were installed two years ago but that was only a few thousand miles
Old Jun 15, 2022 | 07:21 PM
gumby7734's Avatar
If the pins are not lubricated and dirty, they will not move smoothly and cause pulsation,I have had it happen on 09 XFS..
Old Jun 15, 2022 | 08:32 PM
OzXFR's Avatar
Masses of debate over on the Pommy forum about XF (and XJ) "brake judder" and "warped discs".
First and foremost, brake discs do not "warp" but that depends on your definition of "warped". I think it means twisted or bent but some think it means "not flat" at least in the context of brake discs.
99% of the time when someone is talking about "warped brake discs" they are talking about uneven brake disc surfaces caused by uneven brake pad material deposition and NOT bent or twisted brake discs, see here for example: https://alconkits.com/support/brake-...d-brake-rotors
Pad material deposition is most often caused by not properly/fully bedding in the pads to the discs.
Another common cause is applying the handbrake / EPB when the brakes are still hot, causing the rear pads to "imprint" on the discs, or sitting there with your foot firmly on the brake pedal while the brakes are still hot, again causing pad imprint but both front and rear this time.
Back to the Pommy forum debate, the most commonly proffered causes (excluding "warped discs") of brake judder are:
- poor quality / poorly made discs (quite rare in reality)
- sticking caliper slide pins (very common)
- rust build up on the wheel hub faces (not cleaned off before refitting the wheels)
- sticking brake pistons
Of these the most common by far is sticking caliper slide pins.
In turn lots of debate about how to prevent or cure sticking caliper slide pins, some say you should grease the pins others say you should not (as the grease supposedly attracts dirt, grime and especially brake dust). I for one always grease the pins with hi-temp brake grease (after cleaning them) and I have never had brake judder ever, and I have never seen any dirt etc on or around the pins.
Another common cause of sticking caliper pins is rust in the bores they sit in, at least in Blighty. The rust builds up and constricts the holes causing the pins to stick, a good clean out usually fixes the problem.
Old Jun 16, 2022 | 09:03 AM
wimmer's Avatar
Thank you for the insight I think i'm going to pull the calipers myself and check clean and lubricate the slide pins and then roll with it
edobernig
Nov 18, 2021 02:03 PM
Escolar
Aug 11, 2012 08:17 PM
davidcalgary
Jun 22, 2011 08:45 AM
jaguarevan
Aug 7, 2009 09:00 AM
