Need help with OBD code P0017
Old Nov 9, 2019 | 10:15 AM
wcramton's Avatar
Default Need help with OBD code P0017
My 2012 Jaguar XF Supercharged went into Restricted Performance Mode and is idling roughly. My code reader shows this code:
P0017 Crankshaft Position Camshaft Position Correlation Bank 1 Sensor B
I can't find much on here or Google regarding this error for Jaguar specifically. Does anyone have any experience with this one?
Thanks for any guidance
Old Nov 9, 2019 | 12:51 PM
davetibbs's Avatar
1) Clear the codes, see if it reappears. Your idle is rough because once the ECU sees problems with the camshaft timing it puts it into limp-home mode and just stops bothering to adjust the timing (essentially).
2) Swap the camshaft position sensors on Bank 1 (left hand side as you're looking at the engine) with Bank 2 - you may have to remove some things to get at them but it's not too hard. Clear the codes and see if the fault code moves to Bank 2 - it's unlikely the sensor's failed but possible.
3) Next swap the VCT Solenoids from Bank 1 to Bank 2 and see (hope) that the fault moves to the other bank after clearing. If it does, you have a faulty solenoid.
4) If the fault code doesn't move to the other bank after clearing and swapping both sensors and solenoids, it's either a wiring problem (unlikely) or you have a failed VVT, which requires removal of the timing gear to replace.
See attached doc.
File Type: pdf
Old Nov 9, 2019 | 02:18 PM
wcramton's Avatar
Great info. Now I've got something to try.
Clearing the codes did not help - so I'll move to steps 2 and 3.
I'll post an update with my findings - finger crossed.
Old Nov 9, 2019 | 02:26 PM
davetibbs's Avatar
One more question - when you clear the codes, does it come back as soon as you re-read them, or do you need to drive the car to trip the restricted performance message and the code?
Can you start the engine and idle/rev it in park without the message coming up after you've cleared the codes?
Old Nov 9, 2019 | 03:57 PM
wcramton's Avatar
Code comes back immediately just idling in the driveway. Instantly goes into Restricted mode.
Old Nov 9, 2019 | 08:09 PM
davetibbs's Avatar
OK interesting - when I fit a damaged (exhaust) VVT phaser during my engine rebuild I had to creep it forward on idle with a hot engine for it to trip. If it happens immediately on startup it could well be a sensor - let's see!
Old Nov 10, 2019 | 07:39 AM
wcramton's Avatar
I now have this code as well:
P054D Cold Start B Camshaft Position Timing Over-Retarded
Old Nov 10, 2019 | 11:20 AM
davetibbs's Avatar
That code is for Bank 2 - and this is without swapping any sensors or solenoids? If you end up getting errors for bank 1 AND 2 you might want to consider the crank sensor - it's mounted underneath the block on the right-hand side of the engine as you're looking at it, right on the line of the transmission bellhousing. Check the state of the wiring first.
How's your oil level?
Old Jun 17, 2022 | 08:22 AM
Rango's Avatar
Default Help
Originally Posted by wcramton
Did you ever get this figured out? I'm having the same problems. Only with mine it drives normal. No problems, just did a timing chain job. But cleaning codes will stay on saying "permanent" but the check engine light will go away then come back after 5ish miles. Only thing I did was swap bank 1 sensor b to bank 1 senor A. (Well I'm assuming its A, they both are the same type of sensor) I didn't swap both of them out to bank 2. Should I do that step???
xkeots
Nov 16, 2017 10:34 AM
peeterak
Jul 18, 2016 01:10 PM
WaterDragon
May 29, 2016 09:43 PM
Gary Newell
Apr 5, 2016 12:20 PM
Munro
Feb 17, 2016 03:09 PM
