Track Rod End Dust boot
Old Jun 22, 2013 | 03:57 AM
nickgohbc's Avatar
Default Track Rod End Dust boot
Apart from hearing a humming noise when the steering wheel was turned to the left, the cause (rear left tie-rod boot was wear-off) was confirmed after the car was jack-up for an alignment work.
Do any fellow members know the A and B size of the track rod end (Part no. C2Z5517)?
Appreciate your advises because I am struggling to correctly purchase the replacement boots for my XF 3.0 V6 Petrol model.
Regards
Old Jun 23, 2013 | 06:14 PM
Nicholas,
This isn't getting any response in Suspension & Handling section so I've moved it to XF/XFR section for you. Members here with the same model should be able to help.
Old Jun 23, 2013 | 08:23 PM
nickgohbc's Avatar
Smile
Many thanks to you, Graham. Appreciated.
I think most of our fellow buddies will simply change the entire tie-rod kit than taking the trouble to replace the part.
Old Jun 24, 2013 | 09:53 AM
caviarjag's Avatar
I would recommend replacing it as well. If the boot is bad generally the ball joint isn't too far behind. Probably a difference of a $20 part versus a $100 part.
Old Jun 26, 2013 | 02:21 AM
nickgohbc's Avatar
Yes caviarjag, I am considering that option too but what's going amiss is the fun in procuring the correct parts and eventually participating in the hands-on to replace it.
Will furnish the specification to complete the thread once acquire the new part.
H20boy
Dec 24, 2024 03:23 PM
GordoCatCar
Jan 2, 2017 01:10 PM
ym37tech
Feb 8, 2016 01:04 PM
diablomkii
Sep 14, 2015 11:10 AM
obwoodie
Sep 3, 2015 07:45 PM
