Transmission fault; Cruise Control not available
Old Apr 29, 2014 | 12:11 PM
Bnem's Avatar
Exclamation Transmission fault; Cruise Control not available
My 2009 XF started displaying a "Transmission fault...Cruise Control not available" message on start up. When this message is displayed the gear selector does not rise on start up like it should. After waiting for approximately 5 minutes, this message typically clears and the gear selector rises - this may or may not be followed by a check engine symbol, which also clears at some point during the day. Otherwise, the car appears to run perfectly with no noticeable difference in performance - mysteriously, on some days, I don't even get the error message. Does anyone have some insight into what this is about? Would like to know if its an easy fix before the local Jag dealer takes me to the cleaners. Thanks guys!!
Old Apr 29, 2014 | 12:32 PM
nasa25's Avatar
When this happens you should turn the car off and lock the doors. Then try to restart it again. If the car operates as normal after that, then it's most likely the battery.
How frequently does this occur? If it's more often than once every 3-6 months, change the battery and see if that works before getting the dealer involved
FYI this happened to me for the first time a few weeks ago and hasn't happened since. Search through the first 2 pages of threads and you'll find my thread discussing the issue
Old Apr 30, 2014 | 12:00 PM
Bnem's Avatar
Thanks! I had battery issues a few months ago so I went ahead and replaced it yesterday - the messages were gone all day yesterday but returned this morning I guess I'll just bite the bullet and take it to the shop this weekend.
Old Apr 30, 2014 | 12:16 PM
tbird6's Avatar
Please let us know what the problem was.
It's the only way we learn.
Old Apr 30, 2014 | 01:39 PM
nasa25's Avatar
Wow I wonder if this is a software issue. Perhaps a reflash would sort it.
Have you had your original shifter knob replaced under the recall?
Old May 5, 2014 | 04:20 PM
Bnem's Avatar
I was only able to get an appointment at the Jag dealership this morning. Explained the issues to them and after about and hours wait the mechanic explained to me that the entire gear selector, including its module, had to be replaced - he said the codes he found, coupled with the complexity of the issue left him amazed that the car actually drove. 3 hours and $1580 later they assured me I was good to go and the gear selector worked perfectly on start up...only to revert back to all the error messages and the stuck gear selector a few hours later Driving back to the dealer tomorrow. Probably didn't even need the 1.5K new gear selector!
Old May 5, 2014 | 04:41 PM
tbird6's Avatar
If we can get the codes we can help better?
I have never heard of the gear selector causing that problem but who knows.
From your description I think he was throwing parts at it.
Old May 5, 2014 | 07:04 PM
nasa25's Avatar
shouldn't the gear selector have been replaced free of charge under the recall that was done on the 09 model year XF's?
Also check the battery voltage to see if the new battery is working as it should. Its outrageous that the dealer replaced such an expensive part and that didn't even sort the issue.
Old May 5, 2014 | 07:05 PM
nasa25's Avatar
Exactly
Old May 6, 2014 | 06:38 AM
Blackcoog's Avatar
The gear selector was a well known failure in the 09-10 XF. I'm surprised the issue returned after the replacement. As far as I know the replacements always fixed the issue, assuming the replacement was the new revision...
Old May 12, 2014 | 12:55 PM
Bnem's Avatar
The dealer kept the car for 4 days and finally resolved the issue. On the second day they had the car, they called me and practically said they were at a loss as they had investigated almost every likely component only to have the fault message recur. I finally got an email late the 3rd day stating that the valve body and TCM(Transmission control module) had to be replaced. Since they had misdiagnosed and replaced a part I didn't need the first time, this repair, a whopping $4500, was on them and I was offered a loaner! Picked up the car the other day and everything is working great - fingers crossed.
Old May 12, 2014 | 01:01 PM
nasa25's Avatar
Glad to hear it was sorted. Good on the dealership for making things right
Old May 12, 2014 | 01:18 PM
BritCars's Avatar
glad you have it fixed. And all credit to the dealership for a very respectible and honest way to treat you after the initial mis-diagnosis.
mrplow58
Jan 21, 2024 05:53 AM
tomsjag
Jun 10, 2023 10:02 AM
XJsc-guy
Sep 25, 2015 11:09 AM
Skeeter
Sep 17, 2015 08:15 PM
XFR_Gold
Sep 2, 2015 12:24 PM
