Transmission Flush Seals
Old May 7, 2018 | 08:10 PM
santer's Avatar
Default Transmission Flush Seals
If you have had the transmission flushed, did you have these other seals changed along with the mechatronix sleeve?
Old May 8, 2018 | 09:17 AM
clubairth1's Avatar
Community Influencer
A flush is all done externally to the transmission and all the seals you show are internal to the transmission.
You need to drop the transmission pan to replace any seals?
Old May 8, 2018 | 10:31 AM
santer's Avatar
In the UK it is standard to replace the sump pan with mechatronix sleeve as part of the fluid change. Just wondered if they should all be changed while they are accessible
Tom Baker
Nov 3, 2017 06:56 PM
Greykitty
XJ40 ( XJ81 )
Mar 24, 2015 11:46 AM
AlbBolivar
Nov 23, 2013 11:44 PM
dfriedrich208
US Northwest
May 13, 2013 03:00 AM
hawaiianjag
Aug 31, 2010 07:44 AM
