upgrading 2015 XF instrument cluster and headhunt
Old Jan 29, 2019 | 02:42 AM
Bogdan G's Avatar
Default upgrading 2015 XF instrument cluster and headhunt
Hi, everyone.New here.Don't know if that's a new issue, or an old one, but have a question : I intend on buying a 2015 XF 2.0D Premium Luxury, with an analog cluster.Is it possible to swap it for a 2016- digital one ? Do I have to purchase a new one, or a dissembled one will do ? In addition, can I also swap the 8 inch headhunt with an aftermarket 10 inch one (chinese for example, like this one :https://www.aliexpress.com/item/MERR...7bca0d241208e4)
Thanks in advance !
Old Jan 29, 2019 | 03:01 AM
Bogdan G's Avatar
I intended to spell "HEAD UNIT" not "HEADHUNT"....Is there an autocorrect option to this forum ????
Old Jan 29, 2019 | 05:29 PM
lotusespritse's Avatar
That sounds hard. Good luck with that.
Old Jan 30, 2019 | 07:22 AM
JagV8's Avatar
Probably not viable due to the likely specialist programming needed.
Old Jan 30, 2019 | 01:59 PM
Bogdan G's Avatar
Thanks, guys.I think I just might be able to get in touch with someone who's mastering Jag reprogramming.Hope i'll have luck with that
Old Jan 30, 2019 | 08:13 PM
hen555's Avatar
If you switch it to any other cluster not oem for the model then you might be they first one to do it
Bogdan G
XF (X260)
Jan 29, 2019 02:39 AM
car5car
May 5, 2017 09:31 AM
StealthPilot
Apr 21, 2016 05:42 AM
car5car
Feb 15, 2016 07:03 AM
MidnightRyder
XJ40 ( XJ81 )
Aug 2, 2012 05:28 PM
