Upgrading Injectors
Old Apr 15, 2015 | 09:10 PM
PopokI09XF's Avatar
Default Upgrading Injectors
Hello guys!!
I am thinking of upgrading the Fuel injectors since it seems easy to change. The stock ones are 25 lbs and I was thinking 28 lbs or 30 lbs. Have anybody done this yet. It is a 4.2 NA
Thanks,
Chris
Old Apr 16, 2015 | 12:33 AM
Bigg Will's Avatar
Bigger Injectors, unlike a bigger carburetor dose not flow more air, bigger injectors will only flow more fuel, and you can get in a bunch of trouble putting bigger injectors on a car without a tune to regulate those bigger injectors, washing all the oil off the cylinder walls come to mind..lol And then you get into things like injector duty cycle, spray patterns, impedance etc. Believe me, unless you are flowing a lot more air into the 4.2 (Supercharger or Turbo) your stock injectors are plenty.
Old Apr 16, 2015 | 02:22 AM
JagV8's Avatar
The PCM will see the O2 sensors saying not enough air so will reduce the injector on times to compensate for higher flowing ones. Result: if within adjustment limits, nothing useful. If outside limits, an OBD code. You'd need a custom tune to avoid it I think.
I'd stick with OE injectors...
Old Apr 16, 2015 | 02:56 AM
Cambo's Avatar
There is absolutely no benefit of putting bigger injectors on a naturally aspirated 4.2.
None whatsoever...
Old Apr 16, 2015 | 10:56 AM
PopokI09XF's Avatar
Awesome thanks! I would just assume I would make some gains base off some experience with the fords 4.6 and the chevys lt1 and ls engines. You know the bigger throttle body, bigger injectors, free flowing exhaust.
I will just attempt this and see what happens or just get a coyote create motor and drop it in.
Old Apr 17, 2015 | 01:25 AM
JagV8's Avatar
Instead, spend time to understand OBD and closed loop control.
Old Apr 17, 2015 | 12:37 PM
tbird6's Avatar
Yes let us know how the Coyote swap goes!
King Charles
Oct 16, 2015 01:25 AM
jospolice
Oct 2, 2015 07:16 PM
reb1999
Sep 26, 2015 08:41 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
