what differential fluid to use?
Old Sep 15, 2016 | 01:18 PM
carzaddict's Avatar
Default what differential fluid to use?
What differential fluid do you guys recommend to use? what brand does Jaguar use?
Old Sep 16, 2016 | 09:09 AM
Bigg Will's Avatar
I use Redline 75w/90shock proof synthetic. Jag recommends whatever you can only get from the dealer $$$$$..lol
Old Sep 16, 2016 | 03:15 PM
timfountain's Avatar
I used Royal Purple 01300 Max Gear 75W-90 High Performance Synthetic Automotive Gear Oil. I think you'll be fine with anything as long as it is long life synthetic 75W90....
Old Sep 17, 2016 | 10:25 AM
carzaddict's Avatar
perfect, exactly what I needed. Thanks
Old Sep 20, 2016 | 11:51 AM
clubairth1's Avatar
Community Influencer
You are ahead of the game by changing the rear diff fluid. Not many people even check the level!
Old Sep 20, 2016 | 01:54 PM
carzaddict's Avatar
you're giving me more credit than I'm worth. I didnt realize you can check the level haha. i will talk to my mechanic about checking the level. if its lower than normal, hopefully adding more will cure the chattering problem from the back
Old Sep 20, 2016 | 02:57 PM
nasa25's Avatar
With my dodgy pre R41865 diff it's become my life's mission to ensure my diff is always full of fluid lol.
Old Sep 22, 2016 | 06:13 AM
leadfoot4's Avatar
I would say this....if you're going to the trouble of getting the car up in the air, to pull the "fill plug" and check the oil level, why not invest another half hour, or so, and change the gear lube? The hardest part, at least in my opinion, would be getting the car up in the air. Once you're that far, it's just a matter of removing the drain plug, letting the old lube out, and pumping in some fresh oil.
When I changed out mine, after hearing the scare about contaminated XF differentials, I, too, refilled it with Red Line's synthetic lube.
Old Sep 23, 2016 | 11:30 AM
clubairth1's Avatar
That's a good point and one I forgot!
Yes please change it anyway.
Old Sep 23, 2016 | 11:37 AM
Mikey's Avatar
The spec is in your owner's manual. Any fluid that meets this spec will be suitable.
Wolfy
F-Pace (X761) / C-X17
Sep 18, 2016 08:12 PM
tomas6791
XE ( X760 )
Sep 17, 2016 11:47 AM
stuart goodwin
Sep 16, 2016 10:26 AM
stuart goodwin
UK & Eire
Sep 15, 2016 10:09 AM
