what headlight do I have in my 2010 xfr???
Old Apr 9, 2020 | 04:05 AM
Enzo Valetti's Avatar
Default what headlight do I have in my 2010 xfr???
Can someone please tell me if I have a halogen bulb or an HID bulb in my 2010 xfr I've been getting a lot of different things being said to me when I try to buy my replacement bulb on eBay I want to have a nice bright white one compared to the dull yellow that I have now so if I change them for the HIDs or LED or whatever I want to know what the easiest conversion is I want an easy plug-and-play that has a nice white bright light but someone told me I can't do that I have to buy the original lights can someone give me some advice thank you
Old Apr 9, 2020 | 11:25 AM
davetibbs's Avatar
If you have "dull yellow" lights now, that means you def have halogen bulbs and not HID/Xenons. This means that your headlights will not have the drivers required to run HID bulbs, and you basically have three options:
1) Get a pair of OEM HID headlights and fit them - given the cost of pre-facelift headlights (~$600ish used per headlight) this would not appear to be a cost-effective option
2) Get an aftermarket HID kit - these are all over eBay, expect to pay about $100 for a good one
3) Replace your halogen bulbs with LED bulbs - honestly I think the best approach here, you can get good ones for $40 a pair off eBay. I bought a pair for my wife's Mazda 3 and they're absolutely amazing, just as good (if not better) than HIDs. I replaced my full beams with LEDs and it's like daylight in front of the car now.
Old Apr 9, 2020 | 02:01 PM
Default would any led h11 work?
thank you for helping me out I guess I could buy any h-11 LED bulb but some companies on eBay are telling me that the LED bulbs are bigger that they won't fit into the socket can you let me know which ones you think are good I was looking at Beam ju Tech and a couple of other ones
Old Apr 9, 2020 | 05:34 PM
OzXFR's Avatar
As far as I know all XFRs came with bi-xenon (HID) headlights, but even they can and do go weak and yellow after several years.
Easiest way to tell for sure is remove one of the round rubber dust covers off the back of the headlight assembly (very easy, 1/4 turn twist and it falls off) and look in with a torch/flashlight. If you have HIDs you will see the igniter box on the back of the globe, a largish rectangular silver box. If no such box then you have halogens.
Stock 2010 XFR HID globes are Osram Xenarc D1S 4600 K temperature but you can get nicer ones with brighter/whiter light of 6000 K for not much more than the stock globes.
For a MY 2010 make sure they are D1S and not the later/different D2S or D3S which won't work.
Old Apr 9, 2020 | 07:13 PM
prolepsis's Avatar
I noticed the other day that there are small stickers on the top of my light units that state that they are xenon. I hadn’t noticed them until then. Have a look under the bonnet on the top of the light units.
Also, there’s a useful answer in this thread:
https://www.jaguarforum.com/showthread.php?t=120188
Scroll to this post:
Phil F said:09-02-20 03:17
Old Apr 9, 2020 | 07:39 PM
Default lights?
okay do I have to remove the whole headlamp assembly to see this remember I've only owned this car for a month and I'm still getting used to it I read the owner's manual but it also said that it could come with two different like this is so confusing and stupid I'm sure I'll get used to this eventually but coming from a Corvette where it is so easy I guess I'll just have to take it apart
Old Apr 9, 2020 | 07:43 PM
BritCars's Avatar
They are D1S for the xenon bulb in the headlight that came with the XFR. I wouldn't go much above the 4200 level. While 6000 is much whiter / a bit blue tinged it's light output and therefore how it lights up the road is weaker
Note that the full beam is a separate bulb (hence bi-xenon) and that is an H7 I believe. I'd change both at the same time as the headlight unit is a pain to get out if you have the washer jets attached.
Old Apr 9, 2020 | 08:10 PM
Default lights
okay well I don't understand how to find out if they have the right headlight that's bi-xenon or not it's an xfr 2010 and I don't have the window a little washers for the headlights I don't have those so I'm just curious if it was an option or is there an easier way for me to check without taking the entire headlight assembly out and the manual doesn't help because it tells you that you can have the halogen or you can have the other bulb so that doesn't even help
Old Apr 9, 2020 | 08:32 PM
OzXFR's Avatar
No you don't have to remove the headlight assembly to check this, although removing the assembly is actually fairly easy, I did it literally dozens of times across my XFS and XFR.
Just reach in behind the headlight, find the round plastic/rubber dust cover and give it a turn/tweak to unlock it then pull it off.
Also take a tip from prolepsis, you may have stickers on top of the headlight assemblies that tell you if they are HID or not (but I don't remember either my XFS or XFR having these stickers).
Old Apr 9, 2020 | 09:57 PM
Default poc of sticker
so I just posted a picture of a sticker that's on top of the light assembly when I open the hood looks like it says hid check out the picture and tell me what you think so how do I find the originals and are there brighter ones than the originals or should I just stick with the stock ones I just saw them on my eBay there's a pair for $34 I guess it's 6000 light something I don't know I guess 6000 is how bright it is let me know what you think
Old Apr 9, 2020 | 11:22 PM
BritCars's Avatar
If it's a USA spec 2010 XFR then it's definitely bi-xenon. Standard in Premium and XFR.
You should have headlight washers. See the silver shiny piece at the bottom of the headlight assembly between the two main lamps. That pops out and sprays the headlight unit every 5-6 times that you clean the windscreen
Old Apr 10, 2020 | 02:22 PM
Swimref's Avatar
Enzo,
A North American 2010 XF Supercharged (which is what yours is, not an XFR although both use the same headlights) comes from the factory with a bi-xenon HID low beam (or "dipped beam") projector lamp set outboard and a separate halogen high beam (or "full beam") lamp set inboard. Later "facelift" models used a combined outboard unit only. And yes, you do have headlight washers, cleverly hidden when not in use. My model uses exactly the same headlights as yours.
Enzo Valetti
Jan 5, 2020 10:38 PM
PJ704
Nov 29, 2018 07:36 PM
Ellentoft
Other Areas
Sep 19, 2017 02:08 AM
scottchop
Jaguar Press release
Jul 25, 2012 08:46 PM
jaguarevan
Aug 7, 2009 09:00 AM
