Wow HP and Sound
Old May 7, 2014 | 07:36 PM
Gpalace's Avatar
Default Wow HP and Sound
Just recently added Mina exhaust and pulley upgrade and flashed the ECU with Evo. I have K&N filters on order . My 2009 XF Supercharged is a beast to be reckoned with and heads are always turning . With all this HP I just purchased a Quattro for the winter. Kitty will need to take the Winter off. Oh the Joy !
Old May 7, 2014 | 09:28 PM
chXFS's Avatar
Evo? Is that short for something. Is there now a new company offering tunes? I am familiar with ETG, Eurocharged, RSC, Spires, and Paromount. How much?
Old May 7, 2014 | 09:29 PM
Tanman's Avatar
I'm talking to Chris over at Mina about the pulley for my own '09 s/c. Did you do the install yourself? Impressions? Thanks in advance!
Old May 7, 2014 | 09:43 PM
Gpalace's Avatar
Tanman- I had my Speed shop T/T/M here on Long Island due the install as it was tricky for my regular shop. If your mechanical , you should be able to pull with a common ford puller but may have to remove the fan an possibly the radiator. He did put a cut in the eom pulley to remove. Impressions are awesome...my guesstimate without Dyno , I'm pushing about 485-490 BHP.
Old May 7, 2014 | 09:53 PM
Gpalace's Avatar
ChXFS- I need to check with my speed shop...he sent the ECU board to Houston for bench flash...I'll get the name and get back to you.
Old May 8, 2014 | 10:56 AM
Gpalace's Avatar
chXFS- The name of the shop in Houston is Eurocharged...ask for Phil.
Old May 8, 2014 | 11:30 AM
Tanman's Avatar
Thanks for the information. I don't know Phil, but I do know that Jerry over at Eurocharged has been very active and has done a ton of great work for the Mercedes (Benzworld and MBworld) guys. They do good work. I didn't realize they did the Jaguar tunes as well. I wish they were still in Plainfield, IL so I wouldn't have to remove the ECU and ship it.
Old May 8, 2014 | 06:47 PM
Gpalace's Avatar
No problem....they do very good work..the responsiveness is incredible . It was tough being without the Jag for a few days but well worth it. My Tech here said shipping to Houston was the way to go. Just order carbon fiber panels for side vents and Mina through in the emblem for the drive knob. Also 15mm wheel spacers are ordered. Good luck with your Jag
Old May 9, 2014 | 12:49 PM
tbird6's Avatar
You have the 4.2L SC. It will not put out that amount of HP.
Put it on a dyno and see.
The 5.0L SC is a whole nother story!
Old May 9, 2014 | 01:44 PM
Tanman's Avatar
I don't think the BHP stated is unreasonable...420hp base + Pulley&ECU tune of 50-70hp combined total (maybe 25-35hp each). He wasn't talking power at the wheels. Regardless, it's a decent increase at a modest price.
Old May 9, 2014 | 02:36 PM
Gpalace's Avatar
Thanks Tanman!...I understand Tbird6's point with no Dyno to prove it....but yeah ..T/T/M esitimate with 420 base and ECU Tune with Pully and Mina Exhaust 480-490.....65 HP with Tune and Pully alone...5-7 with Exhaust....again guesstimate until im done...and Dyno it!
Putting 15mm spacers on today....and K&N filters in a week.
Ill send a pic when done.
Old May 10, 2014 | 08:56 AM
Tanman's Avatar
I'd love to see pics after your spacers are installed. I've got the K&Ns in now. Noting really noticeable as far as performance (wasn't expecting it to) , maybe a tad louder intake sound, but I've used them in all my vehicles for as long as I can remember. Make sure you tighten all the bolts in the air boxes evenly and securely. I missed one and it created a droning/whistling sound (like blowing over a bottle) on occasion at certain low idle rpm ranges until I tracked it down.
Old May 10, 2014 | 03:29 PM
2010 Kyanite XFR's Avatar
Spacers make a lot of difference on these cars. Did 15 mm on my XFR and it made it look "right".
Old May 10, 2014 | 10:31 PM
Gpalace's Avatar
Kyanite- you are correct. It looks right. Next I will lower 1.2 inches. Will send pics with spacers shortly .
Old May 21, 2014 | 09:41 AM
aliensporez's Avatar
Well, that's convenient
Old May 21, 2014 | 12:28 PM
Gpalace's Avatar
Go get him alien....once you start....
Joachim1167
Nov 7, 2020 09:18 PM
gunlocators
Sep 30, 2015 08:05 AM
Rocky15
Sep 28, 2015 04:59 PM
Long Islander
Sep 27, 2015 03:45 PM
42Ajd
Sep 26, 2015 07:04 PM
