X250 - Park brake warning on XF
Old Dec 11, 2018 | 02:33 PM
BFG's Avatar
BFG
Default X250 - Park brake warning on XF
Does anyone know exactly where the EPB module is on a X250 please? XF 3.0 Diesel 2012
I have the parking brake warning light coming on. The brake works and releases perfectly well, but on engine start I get the warning. I've done quite a bit of reading but threads / google results are across all Jag models.
The battery was getting a bit tired so I replaced that recently, hoping it would solve the problem, but no. I've done quite a few resets.
I think next I need to check the connectors to the module, but I'm not clear where to look.
Old Dec 12, 2018 | 11:04 AM
JagV8's Avatar
It doesn't look too clear in the workshop manual (it's a free download somewhere) but looks to be on the right of the boot probably behind some trim/carpet.
May be near where the fuel filler is (in rather round terms), access from within th boot though.
Old Dec 17, 2018 | 05:43 AM
BFG's Avatar
BFG
Thanks JagV8.
In the boot on the right hand side I have a module which looks completely different from the module others have photographed.
BCMB 6.18 A50025903 Which is a Body Control Module. There are 4 connectors.
I planned to try a re-calibration this morning, and disconnected the battery. At the same time I removed and reseated the 4x connectors on the BCMB several times to make sure there was a good connection.
Unfortunately not only did this fail to remove the warning light, it's made the situation worse as now the parking brake isn't functioning at all.
Edit:
I pulled off the left side boot panel and it's not in there either. Just the amp for the sound system, the keyless entry module and the parking sensors module.
Reading further I tried disconnecting the battery again and shorting out the leads to clear any residual memory. Got even worse. Now I'm also getting warnings about DSC not available.
Jag dealer wants £150 for a diagnostic and the earliest appointment is two weeks away!
X250 BCMB (2012)
Old Dec 19, 2018 | 05:15 AM
JagV8's Avatar
It's not the same as mine, then. Find the workshop manual / electrical guide and hunt through it / them I suppose.
A parts site may help with its location / part # / etc.
Old Jul 8, 2020 | 02:23 AM
Robarco's Avatar
Default Bcmb cx2314d628ag | bcmb 6.18 a50025903 | 7370032840 |
Cx2314d628ag | bcmb 6.18 a50025903 | 7370032840 |
99% bcmb
Cambo
Jan 12, 2022 07:08 AM
coachdrew21
Apr 28, 2019 01:18 PM
nasa25
Oct 13, 2015 07:11 PM
Cambo
Dec 10, 2013 04:26 AM
mlrtime99
Audio/Visual Electronics
Nov 8, 2012 01:37 AM
