XF 3D speed sensor
Old Jun 16, 2019 | 12:53 PM
Zakka's Avatar
From: Oranjemund - far south western corner of Namibia , orange river mouth.
Default XF 3D speed sensor
Hi All,
Is it worth it to clean speed sensors on XF 3D S, 2013 YM , no issues with them at the moment but will be replacing front discs + pads & rear pads incl. brake sensors , so thought about including the ABS sensor cleaning while the 4x wheels are off _ should I even try fix stuff that's not broken? ... I think I will also change out the break fluid at the same time as I do not know when last it was done, if at all?
Any feedback on anything else I should be on the lookout for and/or inspect while the wheels are off will be appreciated.
Thank you
Old Jun 16, 2019 | 03:21 PM
StuG's Avatar
"Is it worth it to clean speed sensors on XF 3D S, 2013 YM , no issues with them at the moment"
If it ain't broke, don't fix it.
Spikepaga
Dec 8, 2017 12:41 PM
XxSlowpokexX
Oct 29, 2014 07:37 PM
rjbaldwin51
Oct 21, 2013 06:17 PM
bt965
Jul 28, 2011 10:07 PM
markocosic
Jan 28, 2011 12:07 PM
