XF drivers heated seat not working
Old Mar 4, 2018 | 03:30 PM
Thefinn's Avatar
Thumbs up XF drivers heated seat not working
Hi my first post here and looking for some advice with a heated seat problem as my drivers seat heat is not working. I have check the fuse which is fine and the passenger seat heat also works as does the cooling fan on both driver and passenger. I have also had the seat up and all the wires look fine with no brakes, so reading other posts it looks like it's either the heating elements or control module. So my question is how can I test these to see where the fault is? Thanks in advance and apologies my first post was asking for advice
Old Mar 4, 2018 | 05:32 PM
Welcome to the forum Thefinn,
I've moved your question from X260 to X250 forum. X260 is the current model from 2015 onwards. Members here with the same model as you have will be able to help.
Old Mar 4, 2018 | 09:55 PM
mleskovar's Avatar
Originally Posted by Thefinn
...either the heating elements or control module. So my question is how can I test these to see where the fault is? ...
Turn on heated seats.... unplug power connector to seat elements.... measure if there's any voltage present
o2manyfish
Nov 11, 2016 01:03 PM
NW1996
Nov 6, 2016 01:26 PM
Sparky77
UK & Eire
Nov 3, 2016 03:58 PM
Matthew Chidester
Oct 8, 2016 04:06 PM
JimC64
Sep 10, 2009 12:44 PM
