XF Light knocking sound at 1st Start
Old Oct 12, 2008 | 07:40 PM
Dennis's Avatar
ud
Default RE: XF Light knocking sound at 1st Start
How many miles on it so far?...And is it the original oil in the engine..?
Are you getting cheap gas ?..In case you are, Try Shell gas next time you fill up.
Old Oct 12, 2008 | 08:57 PM
Dennis's Avatar
ud
Could be..thank God for a warranty..better get it in and looked at..
Old Oct 13, 2008 | 05:45 PM
harounq21's Avatar
My lincoln towncar used todo this. The whole day the car was fine, but in the morning, shifting upwards for the first time in the daywould cause a knock sound. My problem was gunk in the tranny line as well as neglect of tuneup. I can not possibly think what yor brand new XF would have faulty. Hope my advice helps.
Old Oct 17, 2008 | 03:51 PM
Randy's Avatar
i think my XF is doing the same thing.. One single muffled "clunk", coming from the rear as you first drive-off in the morning, at about 10mph, right?
All this time i've assumed that was the truck auto-locking (or something locking) - could that be the sound?
Old Oct 26, 2008 | 09:46 PM
jkviper's Avatar
Randy,
Any update on your single clunk?
My car does the same thing. I normally nose the car into my garage. I have to back it out and then go in reverse down the driveway. I hear the clunk once I put it in Drive and pick up a little speed. like you say about 10 miles an hour.
Old Oct 29, 2008 | 12:26 AM
Randy's Avatar
No update.. it doesnt really bother me that much..
I also nose my car in and reverse down the driveway, which is on a downhill.. i have noticed that the clunk does correspond with changing into 2nd gear.. tomorrow morning i will try to remember to put it into sport-mode which will delay the shift a bit, to see if it still does it right at the shift, or if it's related to the speed..
Old Oct 29, 2008 | 11:16 PM
Randy's Avatar
This morning after backing down the driveway i shifted to S instead of D.. The knock occurred at the exact same speed as usual, ~10MPH, but because I was in S, i didnt hit 2nd gear until 20MPH or so.. so, it appears it is not directly related to shifting into 2nd gear, more related ot the speed or distance traveled.
Old Nov 4, 2008 | 08:39 PM
Dennis's Avatar
ud
I'll be darn..I bet that is it then..I never thought of that..but I know what it's all about..My Hummer does that too for the ABS system, same way...But sounds more like a little relay chatter for a second...The discription of a Knocking sound coming from the engine, had me thinking in another direction.
SD96XJ6L
Jan 12, 2022 04:30 AM
allenman85
May 10, 2021 03:11 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
tberg
Sep 7, 2015 07:32 AM
dcvickers
Sep 2, 2015 06:14 PM
