XF trunk / boot button not working repair pics
Old Dec 22, 2013 | 11:29 AM
JaguarXJR02's Avatar
Default XF trunk / boot button not working repair pics
2009 XF
38,000 miles
Trunk was opening with the key fob and the button by the steering wheel, was NOT opening with the button on the trunk.
pulled back the rubber spring pipe from around the trunk harness that connects the trunk wiring to the car body and sure enough there was a broken wire.
Stripped the wire and crimped it back together, covered with a small heat-shrink pipe
Attached Thumbnails XF trunk / boot button not working repair pics-971a74ec-b233-4fb3-b223-bed808d7a974_zpsd1s5ix1o.jpg   XF trunk / boot button not working repair pics-aea34b16-c8c1-4e44-abc5-eb8669e5c30a_zpszvlkugak.jpg
Old Dec 26, 2013 | 11:08 AM
Long Islander's Avatar
You're missing the rubber boot that all those wires are inserted in. The boot is completely sealed and one end goes into the trunk lid hole and the other goes into the body. Without that, it's not surprising that your wire got cut.
To do a proper fix, you can buy the boot from your Jaguar dealer, then disconnect each wire from the trunk lid side and run each one through the boot. If that seems like too much trouble you can either buy a split loom from Radio Shack and push the wires through the split in the loom, or you can buy some friction tape and just tape the wires together.
Old Jan 2, 2014 | 09:01 PM
I have the rubber thing, I just slid it to the left so I could gain access to everything. It is now reinstalled and looks completely factory.
Old Jun 1, 2020 | 08:13 PM
Mitch's Avatar
Default Same problem
[QUOTE=JaguarXJR02;877245]2009 XF
38,000 miles
How much did it cost to replace
Old May 22, 2025 | 08:04 PM
ACauthen's Avatar
Default This fix worked for me.
I'm grateful that I ran across this thread. I had the same issues and after reading this fix, I discovered the hidden broken wires, repaired t hem, and now I can lock my car with the fob and use the trunk button!
bob5tafford
Jul 22, 2024 12:30 PM
TreVoRTasmin
Apr 8, 2018 08:53 AM
Travis187
May 14, 2017 03:30 PM
wyxtype
Aug 4, 2014 04:16 PM
98JagXJ8L
Jan 29, 2013 03:26 AM
