XFR diff oil
Old Nov 18, 2014 | 04:17 PM
Dan_XFR's Avatar
Default XFR diff oil
Hi all,
I've just bought my first jaguar, a 2009 XFR with 85,000 miles, and currently doing some servicing!
I'm planning on changing transmission fluid/sump filter and final drive/diff oil but I can't find any information on what type of oil should go in the diff!
So my question is what is the correct grade/type of oil should I put in the electronic limited slip diff??
I Don't have a local jag dealer, rang one up but wouldn't give me the spec!
Cheers, Dan
P.s. Love the car!! Unfortunately so does the wife.....and she wants me to buy her one!
Old Nov 18, 2014 | 05:41 PM
nasa25's Avatar
Originally Posted by Dan_XFR
Hi all,
Cheers, Dan
I used amsoil severe gear 75w140 in my 09 NA XF and am pleased with it so far
Old Nov 21, 2014 | 05:01 PM
Dan_XFR's Avatar
For anyone else who may be interested I found out the Correct oil...
Castrol BOT 720 75w90
Just like the Engine oil its only available direct from the dealer at approx. £60 Per Litre
Good news is Land Rover use the same oil in the Electronic LSD
Part No. LR019727 which is LESS then half the price of Jaguar!
Cheers, Dan
Old Dec 1, 2014 | 11:37 AM
raulan's Avatar
How much do you need to refill it completely? Thank you
Old Dec 1, 2014 | 12:24 PM
texsn95's Avatar
Usually til it starts to run out of the fill hole. Or that's how all other diffs have been that I've worked on.
Old Dec 1, 2014 | 05:44 PM
nasa25's Avatar
1.25L or 1.3 quarts
Old Dec 2, 2014 | 11:45 AM
Dan_XFR's Avatar
I used just over a litre, 1.2 - 1.3
I had a noisy diff which was the reason for the change (rumble), It could be felt most when starting from a standstill, going uphill and turning. When I bought the car the seller told me (after paying!) the tires rubbed on full lock...which they don't. It did sound like a rubbing tire though.
The noise/rumble has gone completely now!
NOTE - the oil mentioned above is for the E-diff, not a standard diff or LSD.
Dan
Old Dec 10, 2014 | 02:18 PM
raulan's Avatar
And XFR has ediff?
Old Dec 11, 2014 | 05:08 PM
Dan_XFR's Avatar
And XFR has ediff?
Yes
Old Dec 18, 2014 | 11:27 AM
Bigg Will's Avatar
I used Redline Heavy Shockproof synthetic gear. Red Line Synthetic Oil - ShockProof® Gear Oils - Heavy ShockProof®
RaceDiagnostics
Jul 7, 2022 06:41 AM
Scarecrow
Mar 28, 2016 03:17 AM
SeanU
US Northeast
Sep 20, 2015 12:46 PM
Tim Goz
Sep 17, 2015 09:11 AM
AtholC
Sep 9, 2015 09:07 PM
