Help Needed !!!
Old Nov 24, 2014 | 02:22 PM
Hotrods's Avatar
Default Help Needed !!!
I just bought a 2010 XF 5.0, and it feels like the rear end of the car jerks when coming to a stop, when braking slowly. Anyone have any idea what this could be?
Old Nov 24, 2014 | 02:23 PM
Hotrods's Avatar
By the way the car only has 47,000 miles on it.
Old Nov 24, 2014 | 02:52 PM
lotusespritse's Avatar
Does it seem similar to any of these symptoms?
Jaguar S-Type ZF Gearbox Lurch fault
Old Nov 24, 2014 | 03:13 PM
Hotrods's Avatar
Yes it does.
Old Nov 25, 2014 | 03:24 AM
bollocsk187's Avatar
Check the brakes are not worn down.
Old Nov 28, 2014 | 08:00 AM
Hotrods's Avatar
Brakes are in great shape, I drove it in winter mode and noticed that it is butter smooth and after reading the book it says that it takes off in second gear in winter mode and never gets to first gear. So i am assuming that it is just the way the transmission shifts from second to first when slowing down that causes the bump.
Old Nov 28, 2014 | 01:16 PM
I have 2 2011 XF's and neither of them jerk when slowing in normal transmission mode.
It doesn't seem like they have found a solution for Jags that do that jerking, so maybe that's why the previous owner sold it.
Old Nov 28, 2014 | 02:02 PM
BruceTheQuail's Avatar
If it is the same as what I had with a 2011/12 XF 5 litre, it is fuel sloshing around in the tank, and the dealer will put a foam baffle in the tank to fix it. It feels as though you have a big watermelon in the boot, and it is hitting the back seat when you stop.
Old Dec 18, 2014 | 02:33 PM
Hotrods's Avatar
It is only when it down shifts from second to first when slowing down, because as soon as you push the winter mode button (which keeps it from going into first gear) the jerk goes away. If you turn off the winter mode, allowing it to down shift into first gear, the jerk returns. So it can not be a fuel slosh issue in my case.
Old Dec 18, 2014 | 07:32 PM
sparkenzap's Avatar
You MAY be right, but don't discount the possibility that the mode may make the deceleration more smooth!
Old Dec 18, 2014 | 10:49 PM
Just fill up the tank to very tippy top to test. If the tank is full, it won't be sloshing around because there's no room for sloshing.
Charlene n John
Sep 28, 2015 06:01 AM
Sprayall
Sep 3, 2015 07:49 PM
XJsc-guy
Sep 2, 2015 11:43 AM
innzane
Sep 2, 2015 10:08 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
