XFR and Jaguar Accessory Splashguards
Old Oct 19, 2010 | 05:33 PM
vmaxxer's Avatar
Default XFR and Jaguar Accessory Splashguards
Just thought I'd pass along that although the Jag web-site states that the accessory splashguards won't fit the XFR - seems they will.
I have both rears on and the fronts should be on in the next couple of days. I'll post pics when completed if anyone is interested.
Old Dec 24, 2010 | 10:10 PM
nsl1's Avatar
Please post pictures - I thinking of putting these on my 2011 XF and wondered how they look
Old Dec 26, 2010 | 06:06 PM
jagular's Avatar
They are quite discreet. Being flat black and quite short they hardly show at all. They also work very well to keep some of the muck of the sides of the car, especially the front doors, in bad weather.
Old Dec 27, 2010 | 08:50 AM
vmaxxer's Avatar
Pics attached. Not the best to show them off but they'll have to do until next spring (lol). Hopefully they give you a good perspective on what they look like installed.
Attached Thumbnails XFR and Jaguar Accessory Splashguards-pa210011.sized..jpg   XFR and Jaguar Accessory Splashguards-pa210018.sized.jpg   XFR and Jaguar Accessory Splashguards-pa210019.sized.jpg
Old Dec 28, 2010 | 02:50 AM
ajmarton's Avatar
Did you have to take off the wheels to install the guards? Can you give a brief description on the installation process? I'm curious as I may also get the kit. Thanks, Andrew
Old Dec 28, 2010 | 12:55 PM
nsl1's Avatar
Default Thanks for the pics
Splashguards look great. Thanks for the pic's - Did you install or have dealer install? If you installed was it a no brainier?
Old Dec 28, 2010 | 01:24 PM
vmaxxer's Avatar
I did the install - wasn't too bad. Leave it to Jag to make it harder than it had to be . I ordered them blind as the website says they won't fit the XFR but I can't see why they put that disclaimer up.
Fronts are pretty easy - just turn the wheel all the way left, then all the way right for full access to the mount points. Remove the existing retainers, lift the liners up enough to access the holes (for the retainers) and put speed clips on them, then stick the guards on and tighten with inculded hardware.
Rears are a bit of a challenge and would be MUCH easier if Jag had included hex head screws instead of phillips head hardware, Screws need to be longer for the rears but utilize existing mount points of the liners. The challenge is to get a phillips head driver on the screw with the tire in the way. I did it but looking back I would probably just remove the rear wheels (one per side) for install.
Anyone who is even marginally mechanically inclined (doesn't run scared of boxes marked "some assembly required" ) should be able to handle this with ease. Instructions are included as well.
Old Dec 28, 2010 | 08:58 PM
nsl1's Avatar
Thanks Again for the great info.
Old Dec 29, 2010 | 02:30 AM
ajmarton's Avatar
Thanks for the info. I think I'm going to order a set myself. It does make the XF look a little different from the rest of the crowd. Andrew
D.K
Dec 10, 2023 02:05 AM
paulyling
Mark V - X 420G
Aug 15, 2023 09:33 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
David Thompson
Sep 3, 2015 07:48 PM
