ZF6 rebuild in Los Angeles
Old Mar 9, 2022 | 12:11 PM
rdagger's Avatar
Question ZF6 rebuild in Los Angeles
I have a 2009 Jaguar XF supercharged with 95k miles. Unfortunately, the car is frequently going into limp mode with error code P2704 (Transmission friction element E apply time range/performance). Does anyone know of a good transmission shop in the Los Angeles / San Gabriel Valley area that rebuilds ZF6’s?
Old Mar 10, 2022 | 04:17 PM
VicVegas84's Avatar
Have you done a fluid/filter change?
I would consider looking for a used transmission. I would expect the rebuild on the ZF6 to be expensive, probably more so than a used trans.
Old Mar 10, 2022 | 05:59 PM
rdagger's Avatar
Yes I changed the fluid using the spec'd Liqui moly. Also did the AT plug adapter, valve body sealing, valve body adapter and the AT solenoid kit while they were changing the oil. Unfortunately, my mechanic said it's probably a worn friction disk but he doesn't know Jaguars very well.
Ian Goodchild
Jan 12, 2021 03:09 AM
J-P the Great
Jul 19, 2018 08:11 AM
alspider
Jun 10, 2017 10:27 AM
jbliss
Feb 3, 2011 09:48 PM
GreenJewel
Nov 12, 2009 05:56 AM
