removal of gear box tunnel
Old May 15, 2014 | 12:21 PM
Howie's Avatar
Default removal of gear box tunnel
hi guys.
anybody know the most straight forward way to get the gearbox tunnel out.
it doesn't appear as simple as on the old xj40.
I need to get the gear selector out to change the electric module on the side of it......
cheers
Old May 15, 2014 | 12:46 PM
plums's Avatar
it's been described in earlier threads but you might want to download JTIS from the stickies for the complete procedure
Old May 15, 2014 | 01:09 PM
Howie's Avatar
how do I do that?
Old May 15, 2014 | 02:03 PM
RJ237's Avatar
Just follow the instructions.
https://www.jaguarforums.com/forum/x...archive-65998/
Old May 16, 2014 | 05:59 AM
jimlombardi's Avatar
Look at this other forum thread (view its post# 1) It has instructions and photos on how to remove the gear shifter:
https://www.jaguarforums.com/forum/x...cklight-75330/
Jim Lombardi
Old May 16, 2014 | 12:54 PM
flay's Avatar
10 minutes job. You need a 6 or 8 mm key, a cross screwdriver and a torx (I forget the size, 30-40 I think). Most tricky is to pull out the shifter leather surround trim, usually two credit (or debit?) cards are recommended to take it out.
Old May 16, 2014 | 07:39 PM
Here is the JTIS information on gear shifter R&I - 4 PDF files:
Selector Lever indicator Assembly 44.15.14
https://www.dropbox.com/s/s5a3lesxkb...ly%20R%26I.pdf
Selector Lever Knob R&I 44.15.06 (Transmission Selector Lever Knob)
https://www.dropbox.com/s/pmm51788si...ob%20R%26I.pdf
Selector Gate Finish Panel 76.25.24 (J gate Finisher)
https://www.dropbox.com/s/fhbs5kakti...el%20R%26I.pdf
Floor Console Finish Panel 76.47.26
https://www.dropbox.com/s/b0gsja74j3...el%20R%26I.pdf
Jim Lombardi
Old May 17, 2014 | 06:07 PM
Howie's Avatar
all sorted, just two screws at the rear and two torques up front.......ta
Old Apr 5, 2016 | 03:29 PM
King Charles's Avatar
This came in handy today, kudos sirs.
tomsjag
Jun 10, 2023 10:02 AM
Jandreu
Jun 30, 2022 03:10 PM
cissdm
May 3, 2016 06:02 AM
arnoldmilk
Sep 3, 2015 07:42 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
