XJ ( X351 ) 2009 - 2019
10.5 Android screen
Old Jun 7, 2022 | 04:01 PM
Shaun Flowers's Avatar
Default 10.5 Android screen
I have just received a 10.5 8gb Android screen. I've installed it but I have no sound and when switching back to original platform the unit just reboots?
Ps my car is a 2011 model and my order said 2010 to 2015 yer the box says 2013-2015.
Old Jun 7, 2022 | 06:10 PM
dennis black's Avatar
where did you purchase it from
Old Jun 8, 2022 | 04:12 AM
gloriashield's Avatar
You need to connect aux or bluetooth. Aux is noisy and not recommended. do use bluetooth. however, bt has a drawback in that the sound quality is not good.
Old Jun 9, 2022 | 11:12 AM
clubairth1's Avatar
Community Influencer
Does that unit require the 2 boards from the original unit or not?
We have had major problems with the units that DON'T swap the boards over. The XJ actually has a cooling system built into the dash to cool the Nav screen and the main instrument panel. Without that system operating (and it can't unless the 2 factory boards are swapped over) you will over heat and burn out the Android unit. It already has happened and been reported multiple times.
Does the screen feel hot to touch? This is a BIG clue!
Old Sep 12, 2023 | 04:22 PM
Meanmugga's Avatar
Does the instrument cluster still show the map after installing the Android unit?
Old Sep 13, 2023 | 07:04 AM
clubairth1's Avatar
Yes on my install it does. Again that's was why I only wanted a unit that required the two factory boards to be swapped over. Without that you loose stuff.
Also not mentioned by nearly all the vendors is at least on the X351 XJ the factory has a separate cooling fan and duct system to keep both the navigation stack and the drivers side IP cool. Several people have burned out multiple aftermarket installs because of this lack of cooling. That cooling system is run by temperature sensors in the dash which will no longer be connected with the factory boards if they are absent.
Feel the center screen to see how hot it's running.
Old Sep 13, 2023 | 07:50 AM
Meanmugga's Avatar
Thank you. That was very informative. What year is your car?
Old Sep 13, 2023 | 08:14 AM
clubairth1's Avatar
I have a 2014 XJR and my install is in this thread.
Android Install in 2014 XJR
Lunar Portfolio
Oct 23, 2021 02:44 PM
silversurfer1221
Oct 1, 2021 02:05 AM
coleman645
Sep 2, 2018 10:29 AM
tinmantam
Jan 30, 2016 11:55 AM
guylaurent
Nov 28, 2015 02:45 PM
