XJ ( X351 ) 2009 - 2019
2011 XJ upper grille emblem (badge) removal
Old Jan 12, 2024 | 08:04 AM
Jbelliii's Avatar
Default 2011 XJ upper grille emblem (badge) removal
Has anyone removed or try to take this part of the upper grille badge assembly off. Can it be removed or is it made to the grille and can't be removed. Thank you for your response and input
Old Jan 12, 2024 | 08:41 AM
dmchao's Avatar
Its part of the grille assembly, sort of.
Old Jan 12, 2024 | 08:53 AM
Jbelliii's Avatar
Ok thank you very much I appreciate you
Old Jan 14, 2024 | 11:08 AM
RoonieQ's Avatar
The emblem badge is definitely separate from the grill, and removable. I replaced my original black badge for the red emblem years back. I recall it just being glued (double-sided tape) with locator pins. Dental floss and heat from a blow dryer or heat gun will help.
Old Jan 14, 2024 | 12:24 PM
Jbelliii's Avatar
thanks I appreciate it
Old Jan 15, 2024 | 10:01 AM
dmchao's Avatar
The Badge itself is removable, I was reading OP post to remove the housing where the Emblem sits.
Old Jan 16, 2024 | 05:34 AM
Jbelliii's Avatar
yeah I want to seeif that could be removed as well but if it can be it would have the whole in it where it was
Alexander UA
Oct 13, 2023 11:09 AM
Fenton
Jul 25, 2021 12:16 PM
Jaaaggg
Dec 21, 2018 09:35 AM
ClassicJagMan
Jul 20, 2014 01:42 AM
emaraszek
May 10, 2013 06:18 PM
