XJ ( X351 ) 2009 - 2019
2011 XJL Active suspension system height sensor
Old Nov 7, 2023 | 02:26 PM
Jbelliii's Avatar
Default 2011 XJL Active suspension system height sensor
Good afternoon I have a 2011 XJL and wanted to know if anyone knew where the suspension system height sensor is located. Is there one or two sensors located on the vehicle. Also does this year have the air ride suspension or not. Thanks for y'all's help.
Old Nov 7, 2023 | 03:40 PM
Vasara's Avatar
Height sensors in all corners. On front they are on lower suspension arm and in reat at upper suspension arm.
All x351 have air suspension on rear. Front have steel springs.
Old Nov 7, 2023 | 09:52 PM
Jbelliii's Avatar
Default Thanks
Thank you very much for your help. Much appreciated
Old Nov 9, 2023 | 05:25 AM
kamranki's Avatar
Talking about suspension and height sensors, just curious as to which drive mode provides the highest ground clearance? Or all modes provide same ground clearance?
Old Nov 9, 2023 | 09:01 AM
clubairth1's Avatar
Community Influencer
Since we only have adjustable air springs in the rear there is no way to raise or lower the front of the car?
My understanding is the adjustable rear air springs are to keep the car level with various amounts of weight in the rear seat and trunk.
sboblett
Oct 14, 2023 06:53 PM
Joshua Barrett
Feb 5, 2021 04:56 PM
antdavis1911
Mar 29, 2020 02:07 PM
Lorraine
Dec 4, 2019 04:30 AM
