2011 XJL Electronic Shift Lever (stuck in park) help
Hello,
My 2011 XJL engine seized up and I'm trying to get in neutral. Because the car won't start, there is no access to shift knob. I tried this video below for an XF but seems to be different. I pulled up the trim but chrome piece came up too and couldn't locate Electronic shift lever to release. Can anyone confirm if it's in the same location or if I need to do something different here? There seems to be tons of videos for the XF but can't find anything for the XJ. Any help would be greatly appreciated.
https://jalopnik.com/5531821/how-to-...ic-shift-lever
JJ
JJ
Your release is in the engine bay. It is on the driver side of the supercharger next to the fuel lines. It is marked with red ribbon. You should have a special tool in the trunk that you can connect to it. Once connected all you need to do is twist to about 90 degree and your car will go in neutral.
Good Luck!
Good Luck!
There is a lever located in the center console storage on the left side under the tray that you can place a couple of pens. Pull it up and it should disengage the transmission manually. UPDATED PDF
snooktarpon
20
Feb 17, 2021 08:27 AM
03styper120k
22
Mar 19, 2017 03:08 PM
Acebars
Feb 25, 2015 02:52 AM
