XJ ( X351 ) 2009 - 2019
2012 XJ l Exhaust Tip Replacement
Old Jan 26, 2016 | 05:44 PM
Stentplacer's Avatar
Default 2012 XJ l Exhaust Tip Replacement
Just got CPO XJL would like to change exhaust tips to Quad look.
Any suggestions where I can source chrome tips?
Old Jan 27, 2016 | 02:25 AM
Welcome to the forum Stentplacer,
I've moved your question from General Tech Help to X351 forum. Members here with the same model will be able to help.
Old Jan 27, 2016 | 09:59 AM
Stuart S's Avatar
Default XJ Quad Exhaust Tips
Stentplacer,
See: https://www.jaguarforums.com/forum/x...ips-xj-151318/
They bolt on with no modifications to the existing exhaust system.
I may be able to get one more set. Price is $425 delivered. PM me if you're interested.
Also see: https://www.jaguarforums.com/forum/x...ishers-138212/ I was unable to find any aftermarket "universal" quad tips that would fit without extensive modification to the existing exhaust system.
Stuart
Old Jan 28, 2016 | 11:59 PM
Rostman's Avatar
Just buy an OEM from XJR.
Old Jan 29, 2016 | 04:23 AM
Stuart S's Avatar
They cost over $600.
EXHAUST COMPONENTS for 2014 Jaguar XJR
Old Jan 30, 2016 | 08:58 AM
Rostman's Avatar
Originally Posted by Stuart S
It can't be real thr aftermarket costs more then original OEM part. So yes, they cost a little bit more but you get best quality and original look.
Old Jan 30, 2016 | 01:09 PM
Stuart S's Avatar
OEM are $294.13 each (need L and R) plus shipping, so total delivered will be well over $600. Mine are $425 delivered.
To me, a premium of almost 50% for OEM isn't "a little bit more " particularly when there is no compromise in either quality of manufacture or style. My aftermarket tips look exactly like those on the F-Type V8 R and quality is first class. For details, click the first link in my post #3, above. Why pay 50% more? Your money, your decision.
Old Jan 30, 2016 | 03:12 PM
XJsss's Avatar
I can attest that Stuarts are of superior quality. Also, you cannot just add the XJR "tips" as the XJR rear silencer output exits inner side of the silencer and the "standard" silencer outputs in the center.
Old Jan 31, 2016 | 07:18 AM
Rostman's Avatar
No, you are wrong. Because of you i spent extra $1000 for the rear silencers and center exhaust section, but everything is completelly the same. You just cut the the bigger part of the finisher. You can see the photos in the thread of XJR finishers.
Old Jan 31, 2016 | 08:38 AM
Stuart S's Avatar
Let's have our love of our Jaguars avoid another East-West confrontation.
Old Jan 31, 2016 | 08:54 AM
XJsss's Avatar
My responses are based on a bolt on solution as opposed to "modifications that require cutting and welding, just simply that.
Old Feb 3, 2016 | 11:01 AM
Rostman's Avatar
You are right but it is very easy modification to make it possible to install the XJR finishers. So easy that yo don't need to buy another tail boxes as they are almost completely the same. Even sound is the same. And they cost $400 each. So it is real waist of money.
Old Feb 3, 2016 | 03:07 PM
Stuart S's Avatar
So, do you think I should raise the $425 price of my set? .
Old Feb 5, 2016 | 11:47 AM
Rostman's Avatar
It depends on what do you want from it: sell or not.
Old Feb 5, 2016 | 08:39 PM
Stuart S's Avatar
Rostman,
I wasn't serious - just joking ( an example of sarcastic Capitalist humor). I'm not raising my price.
You said the OEM quad tips cost $400 each in Russia. That was the basis of my attempt at humor - the OEM price in Russia is so high that even if I raised my price by 20% mine would still be a bargain. Being a capitalist doesn't mean you have to be greedy.
Stuart
Old Feb 8, 2016 | 09:54 PM
drsn97um's Avatar
Rostman,
Stuart
Stuart,
Do you still have the tips available?
Old Feb 8, 2016 | 11:16 PM
Stuart S's Avatar
Originally Posted by drsn97um
Stuart,
PM sent.
Old Feb 9, 2016 | 04:17 AM
Rostman's Avatar
Rostman,
Stuart
You understand me wrong.
For now in Russia OEM tips from XJR costs less then $200 each.
I was telling because somebody of you (Stuart S or Xjsss - i do not remeber who exactly said that) said that OEM finishers can't be put on the OEM tail boxes from 5.0 S/C so i spent extra $800 for pair of tail boxes but when i get all the parts i reailised that OEM finisher from XJR can be easily mounted on the stock 5.0 S/C tailboxes only with small cut work ($10-15) and you do not need to waist $800 for whose XJR tail boxes as they are completely the same as standart S/C.
Old Feb 9, 2016 | 06:34 AM
Stuart S's Avatar
... I was telling because somebody of you (Stuart S or Xjsss - i do not remeber who exactly said that) said that OEM finishers can't be put on the OEM tail boxes from 5.0 S/C ... .
See post #8, above.
You were fortunate to buy at those low prices. http://mobile.reuters.com/article/idUSL6N0U13GI20141217
Old Feb 9, 2016 | 07:17 AM
Rostman's Avatar
See post #8, above.
You were fortunate to buy at those low prices. As rouble erodes, Russians buy out last remaining luxuries | Reuters
It was more than 1 year ago. Now it is different.
