2014 xjl warnings lights
Took to dealer because of red warnings telling me; Ignition on, driver side door open and an occasional yellow light telling me Blind spot on drivers side not working They are going to replace the door latch Is this what is causing these warnings
and when I do go in for my appointment what else should I have them check in case this is not the answer. Many thanks, Maria
Delay when using Bluetooth in placing calls
so I thank you for the encouragement that the
dealer is going in the right direction however I
was looking for more information on what my fellow owners knew about any of these problems
Again many thanks
Thank you I will have this checked out
what IYHO 😊 is the best replacement battery and should the auxiliary battery also be replaced
As a woman going in on her own I like to be prepared with just in case information !
even today in 2022 your questions and ideas are dismissed .
very frustrating so thank you all for your
infomation and thoughts
While a Jaguar Dealer can do this and stocks the proper batteries. auto parts stores like Autozone or Walmart have battery services and are much less expensive.and will install a proper battery AGM (Absorbed Glass Matt). The secondary battery is part of the Stop/Start system and if that "feature" is still working or your glad it isn't working (a lot of us didn't like that feature) that is when its replaced and in your situation that battery is available at the dealer @ $400.. Keep in mind a dealer usually charges @ $500 to replace a battery and the auto parts stores are @ $160.
If you still have the original battery, it's time to replace. (probably not the cause of your problems)
WalmartEverStart Platinum AGM Battery, Group Size H8 (12 Volt/900 CCA)
$180. 4year free replacement
Walmart will install for free.
Thank you both so much I can’t get an appointment for a few weeks waiting for latch to come in Will update as soon as I know anything
love and have had a Jaguar for over 25 years
and have never run into these problems until
my independent mechanic who was spectacular
retired. So I really appreciate your help. Maria
John brooks
Jun 10, 2017 10:53 PM
