XJ ( X351 ) 2009 - 2019
3.0 Diesel engine issues
Old Nov 17, 2021 | 09:46 AM
Phil S's Avatar
Exclamation 3.0 Diesel engine issues
Hi, not sure if anyone else has had this issue or if anyone could maybe point me in the right direction but a month or so ago I pulled up in my 2013 XJL in a supermarket car park, the car was running fine. Went inside, came back our and went to start the car and it nearly shook itself to bits. The car had never properly run since and has been at a Jaguar Specialists for the past few weeks who have not been able to solve this issue. At first, they thought the timing had jumped buy upon inspection all was fine. They then changed the injectors which made no difference. Then they changed a pump at the back of the engine, still, no difference, and I have just had a recode done on the ECU which again has made no difference. The garage is left scratching their heads thinking about what to do next and I just wondered if anyone had experienced a similar issue and if so, what the actual fault was. Any help would be greatly appreciated. THanks
TheStick
XE ( X760 )
May 18, 2025 01:38 PM
poppapots
Sep 3, 2020 02:08 PM
Lordpsk
May 22, 2019 08:05 AM
rusty24
Aug 8, 2014 05:42 AM
TonyD
Aug 4, 2013 03:40 PM
