XJ ( X351 ) 2009 - 2019
Battery dead can't access trunk
Old Jan 17, 2022 | 02:53 AM
Jaguardude's Avatar
Default Battery dead can't access trunk
I have a 2011 Jaguar XJ.
I live where it gets very cold (-40) and I made the mistake of letting my car sit for a couple weeks in the cold without starting it. The battery is completely dead and the last time it had any juice I locked the doors so when I attempt to get the trunk open by connecting jumper cables to the connecters under the hood for the trunk the alarm won't stop going off until I disconnect those cables and it doesn't let me open the trunk either. I'm guess it's an anti theft thing does anyone have any idea how to get around this and access the trunk? Or a way to get the alarm to turn off?
Apologies if this is in the wrong area of this site
Old Jan 17, 2022 | 06:14 AM
nicktee55's Avatar
Hi, correct, you're not in the right area!
This is the X260 XF forum. There is an XJ (X351) forum on this site (click here) where people may be able to help you.
Old Jan 18, 2022 | 02:37 AM
Welcome to the forums Jaguardude,
I've moved your post from X260 (XF) to X351 (XJ) forum.
If the Smartkey will not disarm the alarm system or open the door, you will have to use the Emergency Key Blade to open the door. This is from the the UK Owner's Handbook:
Take great care opening the Smartkey case and also when removing the door lock cover.
Old Jan 18, 2022 | 07:46 AM
Thermo's Avatar
Veteran: Navy
Check out this posting, it should do what you are after.
Getting into the trunk when the battery is disconnected - Jaguar Forums - Jaguar Enthusiasts Forum
Granted, I would still look at using the jumper cables to power the car. Yes, you will have to listen to the alarm for 15 minutes, but you should also be able to connect the cables, then lock/unlock the car using the key fob. That should reset the alarm.
Xeno
16
Sep 3, 2021 08:38 PM
bobhoff
Sep 29, 2018 08:14 AM
slidefighter
Apr 29, 2018 07:14 PM
somekidzenvy
Jul 22, 2017 03:53 PM
gagman66
Jan 19, 2017 07:46 PM
