XJ ( X351 ) 2009 - 2019
Cylinder Numbering???
Old Jun 6, 2021 | 09:19 AM
eewhiz's Avatar
Default Cylinder Numbering???
I am trying to replace the coil pack for Cylinder #2, to hopefully correct a misfire problem.. but which one is #2?
Can someone supply a number chart or diagram? Would be very much appreciated!!
Old Jun 6, 2021 | 10:15 AM
Here you go.........
File Type: pdf
Old Jun 6, 2021 | 10:27 AM
Thermo's Avatar
Veteran: Navy
eewhiz, if you open the hood of your car and stand in front of the car, cylinder 2 is the front cylinder on the right side (driver's side for you) of the engine as you are looking into the engine bay.
Old Jun 6, 2021 | 03:18 PM
eewhiz's Avatar
Thanks to all, so it seems like that CYL 1 and 2 should be the easiest to reach??? At least I hope, and that there is no special technique required for replacing the coil packs or Spark plugs. I have replaced DI Coil packs in Saabs and Volvos, so hopefully this will be just as intuitive??
BG44K is going in this afternoon.
Old Jun 13, 2021 | 06:44 PM
NBCat's Avatar
@eewhiz, how many kilometres/miles are on the vehicle?
Quite often a misfire on the AJ133 or AJ126 is caused by a faulty injector. Try swapping the coil units and see if the misfire follows. If not, the misfire is most likely an injector.
Old Jun 15, 2021 | 05:55 AM
eewhiz's Avatar
NBCat, thanks for the reply, the engine has 122k miles. After replacing the coil pack, I did not have the correct spark plug wrench. Worried it may be the Direct injector. This does not look like an easy fix. The car ran for about one week without a misfire, but now is back... cylinder 2 again. Will replace the plug, but am afraid it won't help. Any advice...? Would you trust a good shop to use a Bosch equivalent GDI?
dolamyte
Dec 20, 2015 03:37 PM
Dennis Catone
Nov 7, 2015 11:31 PM
NDW
Sep 30, 2013 07:37 AM
dennisw
Jan 25, 2013 06:23 AM
wheeble
Oct 22, 2009 12:06 AM
