XJ ( X351 ) 2009 - 2019
Dangerous gearbox and engine shutdown on the move.
Old Dec 17, 2022 | 02:25 PM
JS NZ's Avatar
Default Dangerous gearbox and engine shutdown on the move.
2012 V8 SC, done 90T km, dangerous on the move shutdown with resultant brake and steering unassisted
My full symptoms were
1. Rough running initially
2. Jumping out of gear coming up to lights
3. Progressing to full engine shutdown on a slow move say 30-40kmph. The problem was a worn a ngine mounts. Because I drive it hard(I have an SLS Roadster that I truly cane) the engine was moving, an air hose was pulled off as a result. I thought it may have been the gearbox which, given I have just replaced the SLS gearbox for about US$25T, I was pretty unhappy about.
1. Rough running
3. Progressing to engine shutdown on a slow move say 30-40kmph.
But nope 1 worn engine mount did all of it.
My local Jaguar dealer diagnosed it. I was pretty impressed. But they can't get a mount for 4 weeks. I did a bunch of planned work for my first service of the ownership. I see I can buy mounts quicker than them. Are there two mounts(left and right) and are they the same part nos? Is there any better after market option?
__________________
2012 XJ V8 SC Portfolio
Edit Quote Multi Quote Quick Reply
Old Mar 2, 2023 | 11:41 PM
JS NZ's Avatar
Default Engine mounts same as Volvo XC70 FYI - engine shutdown due to worn mounts
So I have replaced both engine mounts. I sourced the mounts away from Jaquar only because they couldn't source for a few weeks. I elected to replace both. On replacement one was gone, the second was on its way. FYI to other users, this was at 95T km or 56T miles. The other interesting thing is that they had XC70( that's right Volvo) stamped on the replacements. I wonder how many other parts are like that. We should build a parts lists on a sticky thread maybe.
Old Mar 3, 2023 | 03:56 AM
JagV8's Avatar
Could be a useful reminder to others to check such things at least annually - and be aware that rough running / jumping out of gear are potentially BIG warnings.
At 10+ years lots of things are getting tired, at the least. Oxygen & heat cycling regardless of miles - but those as well.
Old Mar 5, 2023 | 10:58 AM
clubairth1's Avatar
Community Influencer
If replacing engine mount consider doing the transmission mount as well. They are all part of a system to dampen vibrations. Plus compared to the engine mounts replacing the transmission mount is very simple.
Glyn M Ruck
Nov 14, 2022 05:35 AM
zarnca
Mark V - X 420G
Mar 2, 2020 03:16 AM
Tasng4
Mark V - X 420G
Mar 15, 2018 10:09 AM
a1lry
Sep 13, 2017 03:36 PM
N8HUD
E type ( XK-E )
Nov 11, 2015 09:05 AM
