XJ ( X351 ) 2009 - 2019
DIY XJR hood vents
Old Oct 14, 2024 | 05:51 AM
marcofromtrubulya's Avatar
Default DIY XJR hood vents
There appears to b a dearth of XJR hoods availabe from salvage or wherever so I wondered if anyone has tried to "roll their own" vented bonnet. Is this something a decent bodyshop could do? Thanks for any insight on this!
Old Oct 14, 2024 | 11:58 AM
clubairth1's Avatar
Community Influencer
Yes it's been done and the ones I saw were done quite well!
But it's a lot of work and with all the metal being Aluminum it's takes a lot of skill.
What he did was to make some dedicated press tooling so he could form the metal to hold the vents at the proper level. Then welded the assembly into the non vented hood. While you can get the vents separately it requires skilled metal fabrication to sink the vents in like the factory did.
Installing Hood vents
A quick search is always useful too? here is a quick one to look at.
Hood Vent Installs
Old Oct 14, 2024 | 01:18 PM
Thumbs up
Clubairth1.....As usual, you pros have a quick answer even if it's 1 not so appealing(lotsa work/expense to modify). Thanks so much for your assistance w/my question.
MFT
Old Oct 14, 2024 | 01:23 PM
Next question in the XJR hood quest......has anyone installed the Vehicle Revolution carbon fibre XJR-style hood(dual vents)? Concerned about long-term durability of said hood when having car serviced. Thanks!
polarisnavyxj
Apr 21, 2024 05:53 PM
XJ8JR
Mar 28, 2024 04:09 PM
polarisnavyxj
Feb 25, 2015 04:30 PM
Jaguar Forums Editor
Mar 26, 2014 11:33 AM
Sep 21, 2007 08:44 PM
