XJ ( X351 ) 2009 - 2019
Eco light on/off intermittently and now airbag light on/off intermittently
Old Aug 9, 2021 | 10:53 AM
jaguarxjl's Avatar
Default Eco light on/off intermittently and now airbag light on/off intermittently
2013 XJL Awd portfolio. 90k miles.
Recently, eco start/stop light has been coming on but it goes away, when I stop and restart the car.
Not sure how many hours/days it takes for it to come back on - it seems random.
Now, same thing is happening with the air bag light. Both air bag light and Eco start/stop light come on, but go away, when I restart the car. They both come back on again, later in the day or next day - randomly.
Please advise.
Old Aug 10, 2021 | 09:53 AM
clubairth1's Avatar
Community Influencer
You have a 2013 has the battery been changed?
Old Aug 10, 2021 | 10:56 AM
jaguarxjl's Avatar
You have a 2013 has the battery been changed?.
Yes. about a year or so ago. I had the dealer install the oem Jaguar main battery.
Old Aug 10, 2021 | 02:50 PM
clubairth1's Avatar
That's pretty old for a main battery. We have seen many different things happen when the battery gets older.
So it's usually recommended to start there.
Have you checked for any codes yet?
Old Aug 10, 2021 | 04:01 PM
jaguarxjl's Avatar
I was not clear. To be clear, i had the main battery replaced with a Jaguar OEM battery. Typically, I have the battery replaced every 3 years or so. The local store charges only $120 for a good main battery but I had the dealer replace, only because it had been in for service. I think it was only $220 or so. .Not a huge issue.
I have not checked for codes. Air bag light is no longer on. Only the eco start/stop light is on. I suspect that the aux battery needs replacement. I have posted separately, to find an after market replacement for aux battery. The same battery is around $70 in the UK - Exide EK 151 but I am unable to find a similar size/same round post version. I think if I pull the battery out and take it to a battery store, they might find a replacement.
Old Aug 10, 2021 | 09:05 PM
clubairth1's Avatar
Good luck I think your correct!
Old Aug 19, 2021 | 08:51 PM
Ken Dreger's Avatar
Default Battery for quick start
This was in a prior post: Start battery: https://www.ebay.com/itm/15287241381...YAAOSw2tFaYckz
Cat888
Mar 23, 2016 10:15 AM
Hailers
Aug 14, 2012 10:43 PM
jallender
Jun 6, 2012 10:15 PM
VandenPlass
Sep 21, 2011 11:05 AM
pnyklr
Feb 7, 2010 11:51 AM
