XJ ( X351 ) 2009 - 2019
first aid
Old Feb 5, 2015 | 02:59 AM
ishay karni Eckhaus's Avatar
Default first aid
Coolant radiator hose fail
First aid!
Old Feb 5, 2015 | 03:22 AM
Welcome to the forum ishay karny Eckhaus,
That does look like a Jaguar but definitely not a current XJ351 model .......
Old Feb 5, 2015 | 11:04 AM
Stuart S's Avatar
Default Don't Screw It!
Ishay,
Your radiator hoses will always develop leaks at the clamps as long as you continue to use screw-type (worm gear) hose clamps to replace the original spring-type clamps. Screw clamps do not distribute their grip evenly around the hose and have a high pressure point directly under the screw mechanism. Over time the hose will leak at that point. Spring-type clamps distribute their grip more evenly around the hose and the hose will last longer.
Invest in a pair of spring-clamp pliers to make installation easier. Replace all of your hoses and use the proper size spring clamps.
If this was helpful, please click the Thanks button on the bottom right.
Stuart
Old Feb 5, 2015 | 01:17 PM
indeed.
its my XJ6 X300 sovereign 1996
sorry for that..
ishay
MILOU13
Nov 25, 2015 02:39 AM
simo5555
Sep 9, 2015 06:22 AM
tberg
Sep 7, 2015 07:32 AM
tberg
Aug 31, 2015 04:33 PM
