XJ ( X351 ) 2009 - 2019
Flash the PCM
Old Feb 4, 2020 | 10:22 PM
Robyn Dawson's Avatar
Default Flash the PCM
So I was told by a mechanic but not a Jaguar mechanic that I should flash my PCM. I took it to the dealership they said I needed a completely new engine at approximately $23,000. They gave me five pages of codes showing up. My Master Mechanic at my job site said that all the codes were coming up because of the PCM not being flashed. Does anybody have any information on this?
Old Feb 5, 2020 | 10:34 AM
RedSky's Avatar
'Flashing' a PCM is usually done to update some specific software. It does not typically effect more than one system.
I would get a second opinion on what your car needs.
Old Feb 5, 2020 | 11:27 AM
clubairth1's Avatar
Community Influencer
You either need to buy a new engine or plan many hours of study to understand the Jaguar electronics.
Can you list the codes you have?
Old Feb 5, 2020 | 01:54 PM
u102768's Avatar
It would take someone with the Jaguar diagnostic tools less than 30 minutes to flash your PCM so would cost a lot less than replacing the engine. No harm in trying!
The codes would get cleared as part of that process so you could then see which ones, if any, came back.
Old Feb 5, 2020 | 02:04 PM
Default Codes
I attached the list of codes. Any suggestion would be appreciated.
File Type: pdf
Old Feb 5, 2020 | 04:43 PM
XJ8JR's Avatar
You might just need a new battery. What actual mechanical issues are you having?
Old Feb 5, 2020 | 07:48 PM
RedSky's Avatar
I have never seen a car with that many error codes. I would recommend getting the codes cleared and then starting with a fully charged battery, attempt to start.
Lots of communication errors could be due to water in a moddule.
Old Feb 5, 2020 | 10:52 PM
fossberry's Avatar
I'd say faulty module or bad connection via wiring harness. Seems electrical rather than mechanical.
Old Feb 6, 2020 | 09:18 AM
thierry_1500's Avatar
These dtc do show an electrical/electronic problem, possibly linked to a low battery... in no case IMHO a mechanical one.
if a dealership recommended on that basis to swap the engine I can only advice to run away as fast as you can... they are either incompetent or fishy...
but then there may be elements we don’t have: what is the history of the car before these DTC were read?
Old Feb 6, 2020 | 10:39 AM
clubairth1's Avatar
First I find it very common to have a huge number of historic codes using the SDD. But follow what RedSky said above.
First clear all codes and see what comes back. What your seeing is very much like an event log on your computer. There are a wide range of temporary and fleeting errors that really don't mean anything.
So ignore all of that until you get a fresh scan.
Also listen to XJ8JR about the battery.
How old is it?
Old Feb 6, 2020 | 04:31 PM
dmchao's Avatar
If someone seriously suggested a new engine as the only fix then they have no business getting near anyone's car for an oil change or otherwise. Could be harness, could be a module, could be several or a bad ground wire. You need to find a non-dealer who actually knows how to troubleshoot.
lancia delta
US Mid Atlantic
Nov 26, 2023 03:35 PM
Nasar
US Midwest
Nov 3, 2023 09:57 AM
Racing Green
Feb 1, 2020 10:43 AM
car5car
Sep 14, 2016 01:36 PM
