XJ ( X351 ) 2009 - 2019
Front Sway bar bushings for 2012 Jaguar x351 Supersport
Old Nov 28, 2024 | 12:47 PM
jschimmels's Avatar
Default Front Sway bar bushings for 2012 Jaguar x351 Supersport
I hear a "clunk" noise up front when the car goes over medium to large bumps on the road. Based on my research, I think it is a worn front sway bar bushing. The car handles the same and the alignment is still perfect. I am having trouble finding the exact part number.
Could you all please help me with a replacement part (OEM or equivalent or superior part) and any instructions on how to change?
Thank you for your help.
Old Nov 28, 2024 | 02:33 PM
NBCat's Avatar
Confirm the diagnosis prior to replacing any parts. Disconnect the links and drive the vehicle over the bumps you mentioned to see if the noise disappears. If so, replace the bushes and links.
The front anti-roll bar front bushes have JLR part number C2D5793. The front anti-roll bar links have JLR part number C2D24220.
Here is a link to the X351 Workshop Manual:
https://www.dropbox.com/scl/fo/qlyi6...=v3he40db&dl=0
Old Nov 29, 2024 | 01:23 PM
jschimmels's Avatar
Great idea - thank you.
Old Dec 4, 2024 | 12:37 AM
Nedoerr's Avatar
FYI. Powerflex USA sells polyurethane bushings that will last a lifetime. The unfortunate downside is they often squeak if they are aren’t lubed well with a viscous grease.
Powerflex USA
Old Dec 4, 2024 | 08:38 AM
12jagmark's Avatar
Powerflex USA
And a little on the firm side compared to the OE bushings, not that the OE ones are what most would consider "cushy".
But I consider the added life of them to be well worth it since the X351 isn't the softest riding luxury sedan; more performance - oriented.
Old Dec 4, 2024 | 10:15 AM
jschimmels's Avatar
Here are pictures of the top of the struts. The rubber piece doesn't look worn. What do you think?
Old Dec 4, 2024 | 06:29 PM
wombat's Avatar
js,
The orange granules that are collecting on top of the shock mounts are a tell tale sign that they are on the way out.
As an aside, your coolant is low.
wombat
ricardoa1
Jan 23, 2021 12:29 PM
iownme
Apr 12, 2016 03:59 PM
brgjag
Oct 23, 2015 07:31 AM
tibam13
Oct 3, 2014 08:50 AM
04xtype04
May 4, 2014 09:27 PM
