XJ ( X351 ) 2009 - 2019
Headlight Bulbs
Old Oct 26, 2011 | 12:22 PM
Skforza's Avatar
Exclamation Headlight Bulbs
Anyone know how to get to the headlight bulbs?
they look like they were built so you have to take the whole assembly out.
Old Dec 13, 2011 | 11:48 AM
Skforza's Avatar
Old Dec 13, 2011 | 12:56 PM
JimmyJag's Avatar
I've had replacement bulbs for a few months now. Not really interested in removing the front bumper to swap them. I'm hoping that I can get to the rear of the assembly by removing the front wheels/tires and going through the plastic wheel well.
Old Dec 14, 2011 | 05:20 PM
Skforza's Avatar
I tried that the top screws are very deep. And the headlight needs to be pulled out..
Old Feb 2, 2012 | 05:36 PM
Skforza's Avatar
any jag techs on theses forums that can tell me if there is a easier way to replace bulbs or do i have to remove bumper?
Old Feb 3, 2012 | 03:48 AM
Cadillac's Avatar
Isn't your owners manual illustrating that ? That's weird
Old Feb 10, 2012 | 08:00 AM
xjrguy's Avatar
Sorry so late! Nope, bumper cover has to come off to get at the HID Burners.
Hope this helps!
File Type: pdf
File Type: pdf
Old Mar 2, 2021 | 09:36 AM
carzaddict's Avatar
noticed today when i started up my car that one of the headlights starts up a little more pinkish than the other (until it warms up)...i guess im going to be needing a new headlight soon not looking forward to having to take the bumper off
Im wondering if I can just do the screws on the top....and possibly by the screws by the wheel (which i would rather not do)
Old Mar 2, 2021 | 12:48 PM
tjankovs's Avatar
Unfortunately you have to remove the whole bumper cover! I would recommend high end bulbs. I also turned off the DRL in hopes they will last longer.
Old Mar 2, 2021 | 01:20 PM
dmchao's Avatar
It's pretty easy if you have at least ramps. You don't even need to jack up the vehicle to do so if you turn wheels clock to clock in order to get at the fasteners in the wheel well. Once you pull back each wheel well liner, there are two fasteners one vertical and horizontal that adjust fitment at the front bumper and removing those will allow you to get it free.
Just remember to disconnect the washer hose from the pump at the passenger side. Took me 30 minutes the first time. You'll need extensions to get in tight spaces, use quarter inch tools if on hand.
VancouverXJ6
Nov 29, 2020 11:09 PM
JagGuyMD
Dec 7, 2015 09:31 AM
magnum454
Apr 24, 2015 12:21 PM
dumblecollie
Nov 11, 2009 11:51 PM
christo
Mar 1, 2009 08:27 AM
