XJ ( X351 ) 2009 - 2019
Heated mirror / Fuses
Old Jan 21, 2018 | 01:56 PM
poketastic's Avatar
Default Heated mirror / Fuses
Hello,
One of my heated door mirrors has stopped defrosting. I wanted to check the fuse first but it is not listed in the handbook list of fuses that I can see. Anyone know which fuse or have a list of fuses?
Many thanks, Pete
2011 XJL Portfolio.
Old Jan 21, 2018 | 03:34 PM
dewillia's Avatar
Think they are activated with the rear screen heater
Old Jan 21, 2018 | 08:56 PM
Thermo's Avatar
Veteran: Navy
poketastic, a simple check that you can do is the side that is not heating up, try moving the mirror. If the mirror moves, then you have power to the heater as it shares a common fuse with the computer that controls the door.
If you want to check the fuses, it would be fuse F32 (driver's side) and F30 (passenger side). Both of these fuses should be a 25 amp fuse.
Old Jan 22, 2018 | 04:26 PM
poketastic's Avatar
That’s very helpful thanks, I do have power there. I’ll have to try to pop the glass out and check the connectors.
Smudge67
Dec 16, 2017 09:52 AM
harold72
Nov 8, 2017 09:58 PM
Fairlane500
Dec 9, 2016 10:27 PM
04X-Type3.0
Dec 26, 2012 03:48 PM
Rocafella117
Sep 6, 2010 04:10 AM
