XJ ( X351 ) 2009 - 2019
Help! Electrical issue
Old Dec 16, 2024 | 05:44 PM
Ezbeingme's Avatar
Default Help! Electrical issue
It's me again... I have a 2018 XJR vehicle was put into the shop to have rack & pinion (with motor) replaced. The mechanic called and said the new parts were put in and now it's worse. No power steering! Jaguar says it's electrical issue because they couldn't access the module to troubleshoot. Any suggestions? I appreciate the help.
Old Dec 18, 2024 | 11:48 AM
NBCat's Avatar
A bit more background information would be helpful.
Why was the steering rack replaced?
Was the vehicle involved in an accident?
What, if any, DTCs are stored in the system?
Old Dec 18, 2024 | 05:32 PM
Ezbeingme's Avatar
My previous post
My previous post
Ezbeingme's Avatar
Old Dec 21, 2024 | 04:28 PM
Ezbeingme's Avatar
Default Update
Powe to the car got restored but now Meaning it Works when wheels are off the ground but when I sit it down nothing. Any ideas?
Old Dec 21, 2024 | 05:25 PM
clubairth1's Avatar
Community Influencer
Did you replace any parts?
Your error says steering angle sensor?
Old Dec 21, 2024 | 08:47 PM
Ezbeingme's Avatar
The electric Rack & Pinion was replaced and a new battery (the one in the trunk)
we have power now and steering is great when the car is on the lift but as soon as it's lowered to the ground the steering is tight again.
Any help or suggestions would be appreciated.
Old Dec 22, 2024 | 04:30 AM
Vasara's Avatar
Are the steering wheel straight when wheels are straight forward? Did you keep the Zero steering wheel position during pinion change and did the new pinion had center position when attached to the steering axle? (on modern cars you cant freely rotate the steering wheel/axle, when pinion is detached)
I think you need re-set the steering angle sensor by diag tool after pinion change?
Old Dec 22, 2024 | 07:54 AM
Ezbeingme's Avatar
I am having all these great tips checked on the car. I will update
Old Dec 22, 2024 | 09:49 AM
Ezbeingme's Avatar
Ok, Did that already before it wouldn't let us communicatie with steering module
gpo123
Jan 10, 2025 11:33 PM
D.D.D.
Sep 17, 2024 08:18 AM
Kheitoris
Sep 11, 2024 12:21 PM
Brook
Jun 8, 2024 03:35 PM
Elarja
Jun 22, 2023 03:48 AM
