XJ ( X351 ) 2009 - 2019
How to Find Rear Wheel Stud
Old Mar 14, 2026 | 05:47 PM
jadhelmy's Avatar
Default How to Find Rear Wheel Stud
Does anyone know the part number or where to find the rear wheel stud for the 2013 Jaguar XJ all-wheel drive? Is it possible to find just the stud, or am I going to have to buy the entire hub? Does anyone have experience with changing the studs or hub?
Would greatly appreciate any help.
Old Mar 15, 2026 | 11:31 AM
clubairth1's Avatar
Community Influencer
Last time I got into this (Different car-My old STR) I found that while JLR did not offer wheel studs separately. They were standard wheel studs. I ended up removing the hub. Pressing the old stud out and going to the parts store to match it up. Hopefully someone will read this and post what the stud dimensions are.
From JPART here are the hub part numbers if that will help.
Here is a real rear hub and I found it on Amazon! But not available anymore. You can see these are conventional wheel studs and install like any other ones.
They are about $200-$250 new. Would you consider a used hub? I do see them on EBay for around $100 and the good news is it looks like that part was the same for the entire XJ production and used as well in XF's, XK's and F-Types.
I do see they superseded part number to C2D60511 which is about the same price.
Old Mar 15, 2026 | 05:30 PM
wombat's Avatar
Try this;
https://www.ebay.com/itm/23611138831...O2i6vPMATCb214
M12 x 1.5
wombat
Old Mar 16, 2026 | 08:54 AM
clubairth1's Avatar
Thanks as I knew someone had those specs!
I could not find a part number either so I will post it here.
C2C35294 is the factory lug nut
C2S50885 is the wheel stud which I had not found separately before. This number superseded C2S23549.
Adding to Wombats dimensions they are 42mm long.
For some reason the Jaguar factory parts sites say that does not fit the XJ only the X-Type? But it appears it does fit. I think this stud will fit just about any modern Jaguar
jagxjr
Mar 25, 2024 03:36 AM
P.B.
XJ40 ( XJ81 )
Nov 23, 2023 09:25 AM
Roger95
XJ40 ( XJ81 )
Dec 11, 2019 02:56 PM
sanchez
XJ40 ( XJ81 )
17
May 22, 2018 09:01 PM
CookieMonster
Jun 13, 2017 05:32 PM
