XJ ( X351 ) 2009 - 2019
I Threw My Timing Changing My Drive Belt. Anyone Rebuilt their 5.0?
Old Oct 25, 2024 | 07:49 PM
silvertonesx24's Avatar
Default I Threw My Timing Changing My Drive Belt. Anyone Rebuilt their 5.0?
Well apparently these engines can't be wound backward which I must have done undoing the fan from the clutch. Would have been nice to know, but here we are. Misfires and timing codes and sounds awful and can't be wound manually.
Im assuming piston heads are dented and valves bent.
I see that valves are available on Amazon and euroamp sells a set of pistons
If I recall, these engines were never able to be rebuilt because Jaguar never made internals for it. Has that changed?
Supercharged 5.0
Old Oct 25, 2024 | 10:14 PM
lotusespritse's Avatar
I am sorry to hear that. This is a great warning to other DIYers.
How much did you turn it backwards?
Old Oct 25, 2024 | 10:15 PM
It can't have been much as I was just trying to get a grip on the fan clutch pulley. Apparently this engine does not like being turned backwards at all
Old Oct 26, 2024 | 09:10 AM
clubairth1's Avatar
Community Influencer
The fan is electric? Why did you need to turn the engine at all?
Old Oct 26, 2024 | 10:16 AM
You need to remove the fan to get to the drive belt
Old Oct 26, 2024 | 12:12 PM
clubairth1's Avatar
OK but I have changed belts and never touched the electric fan?
I have a 2014 XJR.
Old Oct 26, 2024 | 12:22 PM
My 2014 RRS has a fan mounted to the pulley, but my old 2011 XF and current 2019 XJL have electric fans. Can you post a picture of your fan assembly?
Old Oct 26, 2024 | 01:18 PM
User 42324's Avatar
https://www.jaguarforums.com/forum/x...ebuild-177468/
Old Oct 30, 2024 | 08:42 AM
clubairth1's Avatar
Yes that Dave Tibbs thread is a real classic!
Amazing amount of work and Dave sure was not afraid to tackle anything!
I learned a lot about the 5.0L engine.
Old Oct 30, 2024 | 11:34 AM
NBCat's Avatar
In case you don't already have them, here is a link to the AJ133 Workshop Training Manual:
https://www.dropbox.com/scl/fi/e7fu9...=xf5jm3t8&dl=0
And here is a link to the X351 Workshop Manual:
https://www.dropbox.com/scl/fi/uaje7...=jawg5pa1&dl=0
Old Oct 31, 2024 | 02:19 PM
AldoRaine's Avatar
I've got a 5.0l I'm going to be pulling in the next week hopefully if you would rather just put that in and rebuild yours over time.
Old Nov 2, 2024 | 11:26 PM
JaguarXJL15's Avatar
What happened? You turned the crankshaft pulley counterclockwise while changing the drivebelt ??
Old Nov 5, 2024 | 09:18 AM
dmchao's Avatar
Oof, sorry to hear of your trouble. If you need pistons I think Mahle can ship you direct, others have called and reference David Tibbs' order.
Or, if you don't want to deal with it. I'm prepping my XJL for sale at a competitive price (PM if interested). Less than a used motor installed at least.
bellrp65
Mar 10, 2019 07:29 PM
sandiford
May 26, 2017 09:46 AM
Supercharged Jag
May 16, 2017 05:36 PM
Jaguarnewbie2011
Sep 28, 2012 07:56 AM
standrew
Jun 8, 2009 02:09 AM
