XJ ( X351 ) 2009 - 2019
Instrument Panel Menu - Service Option
Old Jul 29, 2021 | 09:06 PM
Jbm417's Avatar
Default Instrument Panel Menu - Service Option
I'm still learning about the 2016 XJL - amber engine/trans icon came on today so I wanted to check engine oil level. Found info in manual but am totally confused.
Instrument panel menu section says "Service - displays with ignition on & engine running". When I scroll thru the menus, Service does NOT appear - all the other menus are displayed with engine running.
However in the Fluid Level Check section of the manual it says "switch on ignition (do not start engine) ". How do I switch on ignition - there is no key only the pushbutton? Without engine running there is no Instrument Panel Menu.
Bottom line - how do I check engine oil level?
TIA, Joe
Old Jul 29, 2021 | 10:14 PM
NBCat's Avatar
With your foot off the brake pedal, push the ignition button until the instrument cluster comes on, the scroll to the menu for checking the engine oil level.
Old Jul 29, 2021 | 10:51 PM
Jbm417's Avatar
Thanks very much - as I said I am still learning.
Old Jul 30, 2021 | 10:22 PM
chrisjp's Avatar
TIA, Joe
Yes, the manual is not very clear about how to turn on the ignition without starting the engine. It is not intuitive to push the start button without pressing the brake pedal to achieve this and the manual should make this clear but doesn't.
Old Aug 6, 2021 | 09:42 AM
ca3724's Avatar
Default Check Engine Oil
I found this thread useful, but don't understand the action of hitting the cancel cruise control twice.
https://www.jaguarforums.com/forum/x...folder-165218/
Old Aug 10, 2021 | 03:02 PM
clubairth1's Avatar
Community Influencer
That's only if you are in the service menu and want a "live" oil level reading with the engine running. The normal service to check static oil level is done with the engine on but not running as posted above.
Not sure why you would want a live oil level reading but it is available.
Geardoc
Aug 7, 2021 06:20 PM
marcocomb
Apr 22, 2021 07:18 PM
Colm O
Oct 11, 2018 02:09 AM
JozJag
Jul 16, 2018 12:34 PM
J5hort
Jul 3, 2017 03:40 PM
