XJ ( X351 ) 2009 - 2019
Interior Lighting bulbs LED
Old Nov 25, 2015 | 02:39 PM
JagGuyMD's Avatar
Default Interior Lighting bulbs LED
Hello All,
Today, I changed all of the interior lights to LEDs and also my license plate light bulbs.
My question is how do I remove the front housing where the sunroof switch etc is? I tried but didn't want to break the housing and I figured someone must have removed it before and knows how.
Thanks!
Old Nov 25, 2015 | 03:56 PM
Thermo's Avatar
Veteran: Navy
Get in between the plastic housing and the fabric of the ceiling with a flat blade item (popsicle stick, taped up flat blade screw driver, etc). Once under, pull straight down about 1/2" or a little more. You will hear it pop as the clips let go. Then you can work your way around to the front and undo the 2 clips there.
Worst case, wait till you get to my place and we can do them then.
Old Nov 25, 2015 | 03:57 PM
Thermo's Avatar
Veteran: Navy
Oh, on a side note, do not be alarmed when you see the LEDs glowing faintly at night. This is a problem I noticed when I converted my car over to LEDs.
Old Nov 25, 2015 | 03:59 PM
XJsss's Avatar
I removed mine by using a putty knife inserted 1/2" on the rear sides and pivoting out carefully and then the front side edges
Old Nov 25, 2015 | 04:28 PM
JagGuyMD's Avatar
Thanks. I'll just wait to do those until we do the other stuff. It sure looks a lot better to me with the leds vs the halogen.
Side view mirror puddle lights will be next if they can be removed easily also.
Old Nov 28, 2015 | 07:13 AM
JagGuyMD's Avatar
I went out this morning and popped in out in a couple seconds after seeing a picture of it exposed so I could see where the tabs were.
So from reading, it looks like the front bumper has to come off to access the headlight bulbs?
fingers
Jan 14, 2016 12:33 PM
Tijoe
Dec 10, 2015 09:43 AM
philwarner
Dec 2, 2015 01:25 PM
mkprator
Nov 30, 2015 06:58 PM
arnoldmilk
Nov 30, 2015 06:13 PM
