XJ ( X351 ) 2009 - 2019
Jaguar XJ 351 2012 front passenger door lock removal
Old Oct 19, 2019 | 09:41 AM
NMW's Avatar
NMW
Default Jaguar XJ 351 2012 front passenger door lock removal
Hi
please could anyone help with door lock removal on 2012 XJ I have got so far by removing the inner card and door card but don’t want go to far if its not a DIY thing.
After investigation I have identified the cable from the lock does not move enough to enable opening of the door from outside when using the central locking or remote key phob. The door does open via keyless entry though.
I am pretty certain I need to change the door lock/catch.
Any diagrams or work shop drawings or advice eould be appriciared
thank you
Mark.
Old Oct 21, 2019 | 02:56 AM
christ's Avatar
One of the users on the "other" Jag forum ("TheBoy") posted how-tos for Door Card Removal:
https://www.jaguarforum.com/showthread.php?t=103520
... and door locking motor replacement:
https://www.jaguarforum.com/showthread.php?t=103525
He says it is easy!
Old Oct 21, 2019 | 01:14 PM
NMW's Avatar
NMW
Default Thank you
He says it is easy!
Hi thank you for the information much appreciated.
Mark.
Old Jan 31, 2022 | 12:36 AM
fossberry's Avatar
It can be done at home. I've had to do both front door lock assemblies and in the case of the left hand door, had to do it again when the manual lock cable broke. Actually the little plastic bushing that locates it on the door handle broke. So definitely check this before delving deeper. Either way you'll have to remove the actuator to get at it. A decent set of long torx drivers are your best friend. Just be patient and take it slowly. The areas that really slow you down are:
Prying off and putting on the external lock cover aft of the door handle without breaking off the small plastic tabs that hold it in position. Your friend here...plastic trim removal tools and a soft cloth to protect the door paint. Also great for removing the wood trim along the top of the door and popping the interior trim off the frame. The ones below are what I used:
Relocating the emergency unlock barrel and screw requires patience. There are plastic tabs that hold the lock actuator assembly against the door frame and if they break (like mine did) it'll involve reaching up with one hand inside, pushing the lock assembly against the door so you can locate the screw for the unlock barrel into position and getting the torx screw started.
Moving the door handle into the service position was tricky until I shone a torch up inside to see how it moves and then just pushed it with a thin blade screwdriver from the inside, until the wire harness clicked into the service position.
You can leave the hard to reach actuator cables on and by unbolting the metal brace that runs from the top to the bottom of the door frame, you'll be able to get the actuator out far enough to disconnect the cables and then remove the whole assembly. Carefully study the old actuator anchor points and you'll see a rivet that needs to be drilled out and replaced when you mount the new one on.
First time I did it it took about 4 hours and once I learnt what to do, the other door took about 1 hour.
Wished I'd taken some pics to share with you to explain it easier!
Old May 12, 2022 | 08:15 AM
leaddog11's Avatar
try this
https://www.jaguarforum.com/threads/...-motor.103525/
Old Mar 16, 2023 | 08:06 AM
clubairth1's Avatar
Community Influencer
Default XJ X351 Door Card Removal Instructions
Great links! However they are not labeled properly and I spent a long time finding these. I am posting with the title of the help thread for people doing searchers in the future.
UK Jaguar Forum Door Card removal - With Pictures.
Door Card Removal
Old Mar 16, 2023 | 08:10 AM
clubairth1's Avatar
Default XJ X351 Door Lock and Latch Replacement
UK Jaguar Forum has a great instruction thread on door latch repairs with pictures.
XJ X351 Door Latch Instructions
Old Mar 16, 2023 | 08:13 AM
clubairth1's Avatar
Default XJ X351 Door Lock Actuator Repair
The UK Jaguar forum has a great thread with pictures on how to remove and replace the door lock actuators with pictures.
XJ X351 Door Lock Actuator Removal and Repair
convincor
Oct 1, 2015 05:19 PM
marting
Dec 6, 2011 03:47 AM
ken@britishparts.com
VENDOR 'For Sale' Classifieds
Jul 24, 2007 05:45 PM
