XJ ( X351 ) 2009 - 2019
Last Chance for my 2014 XJL and things went sideways ways half way through...
Old Jun 27, 2023 | 02:25 PM
silvertonesx24's Avatar
Originally Posted by NBCat
Another part that can fail is the coupler from the back of the water pump to the oil cooler, They are now made from aluminium as well to eliminate one more plastic part.
That's this thing right here correct?
Old Jun 27, 2023 | 05:28 PM
NBCat's Avatar
Originally Posted by silvertonesx24
Yes
Old Jun 27, 2023 | 05:37 PM
NBCat's Avatar
@BrettInGalveston, if you haven't done so already, remove the spark plugs and use a cooling system pressure tester to pressurise the system to 1 bar. With the system under pressure, use a bore scope to inspect each cylinder for coolant if the pressure begins to drop.
If coolant is present, the head gasket(s) failed due to the head(s) and or cylinder block being warped.
apllrd
May 1, 2024 06:29 PM
retroren
Oct 18, 2021 06:24 AM
Justin Rouzzo
Apr 13, 2012 08:40 PM
chokeu2
Feb 17, 2011 09:37 AM
GolfJason
Jun 4, 2009 02:16 AM
