XJ ( X351 ) 2009 - 2019
View Poll Results: How to replace or repair
Remove intake manifolds
0%
Plastic repair
0%
Voters: 0. You may not vote on this poll
Massive coolant leak
Old Aug 11, 2021 | 08:17 PM
Drfrankenfish's Avatar
Default Massive coolant leak
Had to get towed home in my 2011 3.0v6 xj as, even though the temp gauge stayed normal, it was clearly overheated. Today I discovered the leak is coming from a plastic split where the top hose joins the ridiculous plastic hose but actually at the face where the plastic hose and return (bypass) hose join onto, there is a third hose also attached. To get to it I some how have to remove the manifold which has the air push fit pipes in a y to both intake manifolds!! How and why, surely I don’t have to remove the intake manifolds-just had one replaced at great cost after the dreaded split…… ideas anyone-I’m stuck without my motor. I’m new here, so thank you.
That is a fountain of bonkersness-wasn’t sure how to add the video, sorry
Last edited by Drfrankenfish; Aug 11, 2021 at 09:27 PM. Reason: Forgot to add video
Old Aug 11, 2021 | 10:18 PM
Mooltan's Avatar
The "Y" shaped part is the Throttle Body and doesn't have any cooling pipes in it.
You may need to remove it to get to a coolant junction box underneath it leakage of which is a "known Jaguar problem".
Its an easy fix. When removing the TB turn it to the passenger side so the drivers side part of the "Y" comes out first.
Otherwise get an workshop manual online (mine cost $19) and follow the bouncing ball.
Old Aug 12, 2021 | 05:01 AM
Thank you so much, yes I deffo need to remove it and did notice there was a larger sleeve on the intake manifold passenger side wondering if that was the option but didn’t want to bust the intake manifold. Is the junction part expensive or repairable with a plastic welder? Thank you for your help
Old Aug 12, 2021 | 09:01 AM
XJsss's Avatar
Just chiming in here. But if you have the older front crossover pipe then I would definitely replace the rear one at this time. These engines are too expensive to replace and the early pipes will fail for sure. So I'd be replacing at the very lease the front and rear crossover pipes.
Old Aug 12, 2021 | 09:29 AM
Fraser Mitchell's Avatar
Is your car the diesel engine or petrol ? Most US contributors won't know much about the diesel engine as it was never exported to the USA.
Old Aug 12, 2021 | 01:27 PM
Vasara's Avatar
Drfrankenfish,
Check this thread: https://www.jaguarforums.com/forum/d...-engine-49261/
I think yours have same part leaking.
You can find complete Service and repair manual from Sticky section of this forum.
Old Aug 13, 2021 | 06:37 AM
Thank you, I’ve identified the part, same as Land Rover and often called the thermostat housing water pipe at anywhere between 20£ and 50£ depending on where from it looks like this:
Old Aug 13, 2021 | 11:07 AM
Originally Posted by Vasara
Drfrankenfish,
Thank you, but mine is 3.0v6 d, I tried to put it in my signature but I’m not sure it’s showing up yet?
Old Aug 13, 2021 | 11:09 AM
Thank you everyone for your help, parts ordered and hopefully I’ll be back on the road very soon…..I don’t think I saved my signature correctly which states the vehicle make model and year, still getting used to this haha
Old Aug 13, 2021 | 11:14 AM
clubairth1's Avatar
Community Influencer
Looks good but you should add the Diesel part as in the US we don't have these are not familiar with their problems.
Old Aug 13, 2021 | 01:28 PM
Thumbs up
I think I just did, good point thank you
Bull27
102
Sep 8, 2023 04:36 AM
JensenHealey
XJ40 ( XJ81 )
Aug 4, 2020 11:59 PM
walkman1
Jun 18, 2020 06:07 PM
giandanielxk8
Jan 29, 2019 06:56 AM
