XJ ( X351 ) 2009 - 2019
MIL code help
Old Oct 15, 2023 | 06:59 PM
drmellis's Avatar
Default MIL code help
Check engine light on and pulled the codes
P00C6
P008A
filled the tank with gas, tightened the cap I thought, and light came on as I was leaving the station. Driving all day just got home. Thanks in advance.
Old Oct 15, 2023 | 07:06 PM
drmellis's Avatar
Oh I did run a bottle of Techron in the tank prior to this one. Seems to start and run fine otherwise just finished a long road trip.
Old Oct 16, 2023 | 04:01 AM
Here's the decode:
As it's running OK, possibly just an out-of-range signal on the fuel pressure sensor. You'd certainly know about it if there was an injector off.
Now you've got the codes, I'd clear them and see if they come back before considering component failure.
Old Oct 16, 2023 | 08:01 AM
drmellis's Avatar
Thank you! Yep ran fine coming to work. Did you pull those codes from a manual, software, Topix,..do you recommend something manual wise?
Old Oct 16, 2023 | 06:06 PM
From the TOPlx Workshop X351 Workshop Manual.
As you probably know, anyone can register for a TOPlx account but almost everything available requires a subscription charged by the hour, day, week, month or year. I paid for one day to download the WM's for both my current Jaguars.
The WM's used to be available as a single document and therefore an easy download but are now in separate sections. 1011 PDF's for my F-Pace which then had to be renamed and merged. A real pain but the best information source.
Old Oct 17, 2023 | 08:25 AM
clubairth1's Avatar
Community Influencer
You did not tell us what car you have?
Hard to say?
Old Oct 17, 2023 | 08:46 AM
drmellis's Avatar
Sorry..thought I did. 2016 X351 5.0L supercharged. Another thought...Just before I filled up with gas the fuel light was on and probably running on fumes.. As I was approaching the gas station, I hit the gas pedal pretty hard up a very steep hill to get there. Could the little remaining fuel "slosh" backwards and cause the low fuel pump to "pull" some air or lose pressure? Anyway, I cleared the code for now. It was/is always running fine...No MIL light after clearing the code yet after I got home on Sunday from the road trip. No symptoms just the MIL light came on at the station on Saturday. Thanks.
Old Oct 17, 2023 | 08:55 AM
clubairth1's Avatar
Thanks much for the car info!
These could be old codes too?
Since you already cleared the code I would just watch to see if it comes back like you said.
It's not uncommon to get things like this from temporary voltage fluctuations and such.
RdoDoc
Sep 8, 2022 10:18 AM
Pattie
Mar 18, 2018 06:44 PM
embibb
Mar 1, 2017 03:57 PM
jagginaround
Apr 29, 2011 02:48 AM
Disco stu55
Sep 7, 2009 04:19 PM
